LCD dislay troubles "Hello World" = "Hdlln Fn
tvnorm
PostPosted: Mon Dec 05, 2005 8:10 pm     Reply with quote
I am trying to get a 2x20 LCD to work.
ITs an optrex with an NT 3881d driver, which as far as Ican tell is a Hitachi HD44780 clone. I can place charcter wherever I want, top row, bottom row, but some of the characters are always off. Looking at the standard character codes, the incorrectly displayed charcters are always to the left,right, top, or bottom of the intended character in the character table from the data sheet. This would seem to indicate a timeing issue to me, but I am new to pics and programming in C. I am usingLCD.c but modified to use all of portc, because that is the 8 bit port on p16f690.
Can anyone be of assistance?
#include <16F690.H>
#fuses NOWDT, NOPROTECT
#use delay(clock = 4000000)
#include <lcdportc.c>
lcd_init();
lcd_putc("Hello World");
PostPosted: Mon Dec 05, 2005 9:07 pm     Reply with quote
I don't know what compiler version you have, but I looked at the
.LST file for PCM vs. 3.240, and the CCS setup code is incorrect
for the comparator registers.
You should be able to fix it by adding the line shown in bold, below:
lcd_init();
If that doesn't fix it, then post the version of your compiler.
tvnorm
PostPosted: Mon Dec 05, 2005 9:25 pm     Reply with quote
That Got it!!!!!
Hello World never looked so nice.
THANK YOU
