timer 3 is never getting executed? must be something simple
Posted: Sat Dec 03, 2005 6:19 pm
This code is for a pic18f4455 with 4 built in timers and one ccp module.
I'n trying to use timer 3 as a simple counter, but when i noticed it wasnt counting I added a printf.. and nothing shows up. so I must have messed up somewhere. Anyone have an idea of what i did wrong,
setup_ccp1(CCP_CAPTURE_RE); // Configure CCP1 to capture rise
setup_timer_3(T3_DIV_BY_8);
enable_interrupts(INT_TIMER3);//constantly counting but only used for RPM
enable_interrupts(INT_CCP1); // Setup interrupt on falling edge
enable_interrupts(INT_TIMER1);//constantly counting but only used for RPM
main loop....
Nick Guest
Posted: Sat Dec 03, 2005 7:11 pm
I moved to timer_0 and it worked, i must be missing a concept here?
Nick
drh
Joined: 12 Jul 2004 Posts: 194 Location: Hemet, California USA
Posted: Sat Dec 03, 2005 9:20 pm
Change:
To:
setup_timer_3(T3_INTERNAL | T3_DIV_BY_8); _________________ David
