How do you enable 4 PWM outputs on PIC18F4320?
Neil Smith
PostPosted: Fri Jun 13, 2003 3:41 am     Reply with quote
I am having trouble enabling the 4 PWM outputs available on the PIC18F4320 - it's part of the Enhanced CCP module.
I would like to use them as 4 separate PWM's all running off TMR2 but with different duty cycles.
In the data sheet it says (16.0 ECCP Module) - 'The ECCP module differs from the CCP with the addition of an enhanced PWM mode, which allows for 2 or 4 output channels...'
CCP1CON allows you to setup ECCP
CCP1CON<3:0>
1100 = PWM mode; P1A, P1C active high; P1B, P1D active high
but then...
CCP1CON<7:6>
00 = Single output; P1A modulated; P1B, P1C, P1D assigned as port pins????????????????
Does this mean that the ECCP only allows these 4 PWM outputs to be used as part of the Bridge modes??
___________________________
Original Post ID: 144515205
R.J.Hamlett
Re: How do you enable 4 PWM outputs on PIC18F4320?
PostPosted: Fri Jun 13, 2003 5:25 am     Reply with quote
:=I am having trouble enabling the 4 PWM outputs available on the PIC18F4320 - it's part of the Enhanced CCP module.
:=I would like to use them as 4 separate PWM's all running off TMR2 but with different duty cycles.
:=In the data sheet it says (16.0 ECCP Module) - 'The ECCP module differs from the CCP with the addition of an enhanced PWM mode, which allows for 2 or 4 output channels...'
:=CCP1CON allows you to setup ECCP
:=CCP1CON<3:0>
:=1100 = PWM mode; P1A, P1C active high; P1B, P1D active high
:=but then...
:=CCP1CON<7:6>
:=00 = Single output; P1A modulated; P1B, P1C, P1D assigned as port pins????????????????
:=Does this mean that the ECCP only allows these 4 PWM outputs to be used as part of the Bridge modes??
Basically yes.
The possible output configurations, are illustrated as figures 16.2 onwards. You can have a total of four outputs, but only two at a time carry PWM signals.
I have never 'played' with trying to generate four signals like this, on the new chips, but two possible solutions exist:
The first is that you may be able to use the units in CCP mode. You would have to look to see if you can have four seperate CCP outputs?.
The second (if the frequencies needed are not too high), is to consider a 'phase machine', driven off one timer, probably with the interrupt handler written in assembler, to control the four pins. I have done this in the past on chips with less sophisticated CCP modules.
Original Post ID: 144515206
