bad communication between pic and pc
Milo
PostPosted: Thu Jun 12, 2003 1:47 pm     Reply with quote
Hey all, ... I am having a problem when connecting pic to pc. I can print messages to pc using printf statements, ... However, when it comes to putting characters from pc to pic, the whole thing crashes. Seems like whenever i try to use
getc(), everything goes down the drain. Here is a program I am trying to test, ... As you can see, program should work only when it receives lowercase l from pc, ... However, it works with any key pressed, ... Sometimes it even crashes and generates garbage, ... Most of the times it doesn't work at all, ... I am not using MAX232, therefore I used INVERT option in my #use rs232 directive, ... Also, my clock is external 20 MHz, ... The wave looks more like a sinusiod than square, ... Could this be a problem?, ... Anyway, here is the code, and if you have any sugggestions, help is always welcome, ...
#include <16F84A.h>
#fuses HS,NOWDT
#use rs232(baud=9600,parity=N,xmit=PIN_B1,rcv=PIN_B2, INVERT)
byte answer;
//setup_counters(RTCC_EXT_L_TO_H,RTCC_DIV_2);
#use standard_io(A)
SET_TRIS_A(0x00); //ALL A PINS AS OUTPUTS
OUTPUT_LOW(pin_A0);
OUTPUT_LOW(pin_A1);
OUTPUT_LOW(pin_A2);
OUTPUT_LOW(pin_A3);
#use standard_io(B)
SET_TRIS_B(0x04); //B2 INPUT; B1 OUTPUT;
OUTPUT_B(pin_B1);
OUTPUT_LOW(pin_B0);
OUTPUT_LOW(pin_B3);
OUTPUT_LOW(pin_B4);
OUTPUT_LOW(pin_B5);
OUTPUT_LOW(pin_B6);
OUTPUT_LOW(pin_B7);
disable_interrupts(GLOBAL);
disable_interrupts(INT_RTCC);
disable_interrupts(INT_RB);
disable_interrupts(INT_EEPROM);
disable_interrupts(INT_EXT);
putc(13); //this is where the problem occurs
delay_ms(85);
do{
answer=getch();
}while (answer!=0x6c);
printf("Emergency!... Emergency!... Emergency!... \n");
putc(13);
___________________________
Original Post ID: 144515188
Re: bad communication between pic and pc
PostPosted: Thu Jun 12, 2003 2:17 pm     Reply with quote
Do you have a 10K resistor on Pin B2 ? If you're not using
a MAX232 chip, then you need the resistor.
:=#include <16F84A.h>
:=#use delay(clock=20000000)
:=#fuses HS,NOWDT
:=#use rs232(baud=9600,parity=N,xmit=PIN_B1,rcv=PIN_B2, INVERT)
:=void main()
:= byte answer;
:= //setup_counters(RTCC_EXT_L_TO_H,RTCC_DIV_2);
Standard I/O is the default. You don't have to specify it,
unless you're switching to fast_io at some other point
in the program.
:= #use standard_io(A)
:= SET_TRIS_A(0x00); //ALL A PINS AS OUTPUTS
:= OUTPUT_LOW(pin_A0);
:= OUTPUT_LOW(pin_A1);
:= OUTPUT_LOW(pin_A2);
:= OUTPUT_LOW(pin_A3);
:= #use standard_io(B)
:= SET_TRIS_B(0x04); //B2 INPUT; B1 OUTPUT;
This next line is not correct. You're writing the value
for "pin_B1", which is 49 (0x31) to Port B. I doubt that
this is what you intended to do.
:= OUTPUT_B(pin_B1);
:= OUTPUT_LOW(pin_B0);
:= OUTPUT_LOW(pin_B3);
:= OUTPUT_LOW(pin_B4);
:= OUTPUT_LOW(pin_B5);
:= OUTPUT_LOW(pin_B6);
:= OUTPUT_LOW(pin_B7);
These interrupts are disabled upon power-up.
You don't need to turn them off.
:= disable_interrupts(GLOBAL);
:= disable_interrupts(INT_RTCC);
:= disable_interrupts(INT_RB);
:= disable_interrupts(INT_EEPROM);
:= disable_interrupts(INT_EXT);
:= putc(13); //this is where the problem occurs
:= delay_ms(85);
:= do{
:= answer=getch();
:= }while (answer!=0x6c);
:= printf("Emergency!... Emergency!... Emergency!... \n");
:= putc(13);
The PIC will go to sleep right here. Do you want that ?
If not, put this statement here:
Original Post ID: 144515191
Milo
PostPosted: Thu Jun 12, 2003 2:54 pm     Reply with quote
Thanx a lot man, ... The program works perfectly now, ... Milo
Original Post ID: 144515192
