Help, am I stupid or what ?
MikeW
PostPosted: Tue Nov 29, 2005 3:57 am     Reply with quote
I just cant see the wood for the trees, why wont this go round the loop 50 times ?, it just falls through.
I can see why, because the BRA instruction is an unconditional branch.
is it me, or is it a compiler error V3.238 pchw, PIC18F4480
for (LED_Counter=50;LED_Counter>=0;LED_Counter--)
Flow_LED_Brightness=LED_Counter;
compiles to
................... for (LED_Counter=50;LED_Counter>=0;LED_Counter--)
183C: MOVLW 32
183E: MOVWF LED_Counter
.................... Flow_LED_Brightness=LED_Counter;
1840: MOVFF LED_Counter,Flow_LED_Brightness
1844: DECF LED_Counter,F
1846: BRA 1840
PostPosted: Tue Nov 29, 2005 4:47 am     Reply with quote
Change LED_COUNTER, to a signed type.
The problem is that for an unsigned value, LED_COUNTER>=0, must _always_ be true. Hence no test is done, and there is a permanent loop.
MikeW
dont like to used signed
PostPosted: Tue Nov 29, 2005 5:12 am     Reply with quote
thanks for your reply.
I think i prefer to do this though...
for (LED_Counter=50;LED_Counter!=0;LED_Counter--)
Mike
PostPosted: Tue Nov 29, 2005 5:18 am     Reply with quote
However this gives one less count. If you want to have the same number of counts as before, you need to increase the initial value by one.
MikeW
PostPosted: Tue Nov 29, 2005 5:50 am     Reply with quote
Ttelmah, once again, many thanks.
the actual count in this instance is not important for me since I am just testing the PWM'ing of some LEDS to test varying brightness, but i do take your point.
Mike
gremlin
PostPosted: Tue Nov 29, 2005 8:39 am     Reply with quote
It is actually quite interesting, that the compiler optimisation is 'smart' enough, to realise that the original test, could never go 'false'. This is one of an increasing number of cases, where this sort of thing happens. I'd have expected that there may actually be a 'warning', that the condition is always true (there are quite a few warnings like this, that only appear if the error reporting is turned up, since they are normally an 'annoyance').
