XorpiZ Guest
Problems with strtok() |
Posted: Sat Nov 26, 2005 8:19 am |
Hi, i'm having a few problems with strtok().
I've tried using the example given in the reference sheet.
My program looks like this (plus the defines, includes etc)
char raw_nmea_data [65];
char term;
char *ptr;
strcpy(raw_nmea_data, "$GPRMC,150022.721,V,0000.0000,N,00000.0000,E,0.00,0.00,251105,,*16");
//strcpy(raw_nmea_data, "one, two, three");
term = ',';
ptr = strtok(raw_nmea_data, term);
while(ptr != NULL)
puts(ptr);
ptr = strtok(NULL, term);
See, now the problem is. If i use "strcpy(raw_nmea_data, "$GPRMC,150022.721,V,0000.0000,N,00000.0000,E,0.00,0.00,251105,,*16");
the output on hyperterm looks like this
$GPRMC
7
V
N
And thats obviously wrong..
But if i use "strcpy(raw_nmea_data, "one, two, three"); it looks like this
one
two
three
Just like it's supposed to. Why doesn't the other one work?
Any hints, tips, pointers etc. very much appreciated [/code] |
Posted: Sat Nov 26, 2005 8:55 am |
Well I figured it out..
use strcpy(term, ","); instead of term = ',' and char term[2] instead of char term; |
Posted: Sat Nov 26, 2005 10:03 am |
It makes sense when you realise the a 'string' in C, is a sequence of characters, with a null terminator. Your previous declarations, declared a character, but not a 'string'. You can just declare:
char term[2] = ",";
Which will declare the string, and pre-initialise it with the required value,all in one go. :-)
