is there a way to retrieve the source code again?
guest
PostPosted: Wed Nov 23, 2005 1:48 pm     Reply with quote
I accidently deleted all the source code, but I still have the object flashed in the chip. I could read the object file from the chip out ( I hope!)
Is there a way can we convert from the object file to the source code again?
Many thanks.
Jim
PostPosted: Wed Nov 23, 2005 2:21 pm     Reply with quote
yeah, you can retrieve the assembly, but it will be all hexadecimal digits and assembly code. You're better off re-writing the program from scratch.
I think you would use MPLAB to do that. And the chip must not be secured from reading.
SherpaDoug
PostPosted: Thu Nov 24, 2005 1:16 pm     Reply with quote
A disassembler will get you the assembly code. There is probably one out there somewhere for your PIC. I know of no way to get the C code back.
Beware some may suspect you are trying to steal someone else's code!
Kieran
PostPosted: Thu Nov 24, 2005 2:15 pm     Reply with quote
The list file includes the source, with editing its posible to recover the source.
Mark
PostPosted: Thu Nov 24, 2005 10:42 pm     Reply with quote
Look in the recycle bin Laughing
