DS1307 power from pic controler.
Gerrit
PostPosted: Thu Nov 24, 2005 8:24 am     Reply with quote
Hi all,
Some hardware question. I'm doing a project with battery, micro and
clock chip.
I have to do power saving.
first, Can I switch the ds1307 from my microchip controler on/off (using backup battery on ds1307)
second, when I do sleepmode in de microchip controler (power pin ds1307 is high)
and I want to let the power on the ds1307 is this going to be.
Any help is welcome.
Regards,
Gerrit
Humberto
PostPosted: Thu Nov 24, 2005 12:09 pm     Reply with quote
Yes. the DS1307 can drain its power from a PIC output pin.
You can switch on-off the Primary Power Supply (Pin 8) as needed, when the DS1307 trigger its power fail detect, it enter in power save mode (having a 3V battery back up connected in Vbat (PIN3) of course).
While in power down mode, the DS1307 keeps running the timekeeper function but inhibit further access to read/write registers.
Humberto
Gerrit
PostPosted: Thu Nov 24, 2005 4:25 pm     Reply with quote
Humberto,
Thanks for explaining it. But for me the second question was a little
bit different intend.
what I want to know is can I drain power from a micro pin when it is in
sleep mode
PostPosted: Fri Nov 25, 2005 3:26 am     Reply with quote
Yes.
Pins remain 'driving' the way they are set, when a chip goes to sleep. This is why, if you want to reduce power consumption to a minimum when sleeping, it is important to set pins that are driving, to the state where they don't drive. So, yes, you can drive a device when you send a chip to sleep, but with the obvious 'caveat', that the power consumption of the PIC will then rise.
kender
PostPosted: Fri Nov 25, 2005 3:33 am     Reply with quote
I wonder: why would one want to give RTC full power supply while the PIC is asleep? In other words, PIC is asleep so there is nobody to query the RTC. Why RTC needs full power when PIC is asleep? It can maintain time on just the backup battery.
