PIC16F818 not Oscillating
JohnKennedy
PostPosted: Tue Nov 22, 2005 5:07 am     Reply with quote
Hi
Just built up a new board and the PIC isn't oscillating at all (checked using a scope). I have checked the following:-
5V supply is fine.
MCLR is at a steady 5V.
0.1uF directly across 5V supply pins.
No errors whilst programming.
Replaced 4MHz resonater and Pic for a new ones.
Any other suggestions as to what could be causing this. I know it's not down to the pcb as I have had multiple applications use this pcb before without any problems.
thanks
JFK
PostPosted: Tue Nov 22, 2005 6:48 am     Reply with quote
What fuses are you using?.
A
18F not oscillating
PostPosted: Wed Nov 23, 2005 4:32 am     Reply with quote
Not looked at this particular device but check it's not configured for low voltage programming...
use:
#fuses NOLVP
An alternative is to pull the PGM pin low.
PostPosted: Thu Nov 24, 2005 2:04 pm     Reply with quote
when u programing the pic, use config word $3f10, int the code must be select internal osc 8MHz.
It must be work correctly, if your program ok, and the pic is not dead
by tibi
