jim Guest
| Using PORTD & External ram |
Posted: Fri Aug 31, 2001 6:27 am |
I have a PIC16F877 and I connected an external parallel ram to it.
PORTD is my data bus.
my question: is it ok to keep changing the port from an in to an out every time I want to read / get the data ?
what I do now is make the port an output using "set_tris_d(0x00);"
then I write data to ram.
then when I want to read it I make the port an input "set_tris_d(0xFF);" and then read the data.
am I doing this right ? or have I totally missed something.
Thanks, Jim
___________________________
Original Post ID: 126 |
Doug Kennedy Guest
| Re: Using PORTD & External ram |
Posted: Fri Aug 31, 2001 6:55 am |
:=I have a PIC16F877 and I connected an external parallel ram to it.
:=PORTD is my data bus.
:=my question: is it ok to keep changing the port from an in to an out every time I want to read / get the data ?
:=what I do now is make the port an output using "set_tris_d(0x00);"
:=then I write data to ram.
:=then when I want to read it I make the port an input "set_tris_d(0xFF);" and then read the data.
:=am I doing this right ? or have I totally missed something.
:=Thanks, Jim
Yes this works fine for me aslong as the read write memory line is syncd
( you don't want to read while you are writing thus having the SRAM and portd fighting each other )
Original Post ID: 127 |
John P Guest
Posted: Fri Aug 31, 2001 2:58 pm |
Yeah, I've done this, also using PORTD. I used two 74HC374 octal buffers to store first the low, then the high, address bytes, then to write I put the data on PORTD and activate an additional strobe to load it to the RAM. To read, turn the port into inputs and hit a strobe to activate the RAM's -OE line. So you need the 8-bit port and 4 additional control lines (strobe addr high, strobe addr low, read and write). It's cumbersome, but it does work.
I also took the outputs from the octal buffers and connected each one to an LED. The address lines have no effect when the RAM isn't read or written, so I do a "dummy operation" which sets the address bits but doesn't read or write. By doing this at a suitable rate I've set up a "bouncing light" which goes up and down the row of LEDs twice a second or so. It's fun and it also verifies that every address bit is functioning and that the processor's timing interrupt is working.
Original Post ID: 139 |
Robert Guest
Posted: Sun Nov 20, 2005 7:37 am |
Could you please tell me what RAM chip you use?
| jim wrote: | I have a PIC16F877 and I connected an external parallel ram to it.
Thanks, Jim
