Where can I get a NE2000 compatible ethernet card ??
arunb
PostPosted: Sat Nov 19, 2005 6:03 am     Reply with quote
Where do I get a NE2000 compatible ethernet card?? Is it easily available.
It would be easier for me if I get a weblink so I can read the specs for the card, also will Realtek card be OK ( These are commonly available here, they use PCI bus though). ??
thanks
arunb
asmallri
PostPosted: Sat Nov 19, 2005 9:06 am     Reply with quote
These are very commom. You can pick them up at any flea market or PC surplus store. Most NE2000 compatible cards I have come across over the last few years have been based on the RealTek RTL8019AS.
The RealTek chip works in PCI and ISA mode but ISA is the easiest of the two to implement with a PIC.
Regards, Andrew
arunb
RE
PostPosted: Sat Nov 19, 2005 8:53 pm     Reply with quote
Thank you for the reply..
My PC store has a Realtek based card, in fact we use it in all our computers, the problem is that ISA cards are not easily available these days, is it not possible to use PCI instead,
Kindly post some info on PCI bus and how a PIC can use it.
Please also post info on using a ISA bus.
thanks
arunb
asmallri
Re: RE
PostPosted: Sat Nov 19, 2005 9:04 pm     Reply with quote
arunb wrote:
I doubt if we are talking about the same Realtek chip. The simplest once to interface to a PIC is the RTL8019AS which is a 10MBps only Ethernet controller. I would be surprised if you can buy these new on a PCI bus today.
Can't help you. I doubt it is practical to implement a PCI bus with a PIC just to do Ethernet. However, as mentioned previously, A RTL8019AS supports both PCI and ISA busses. It may be possible for you to get a PCI version and butcher the card to enable you to talk to it as though it was an ISA connection.
There are lots of examples of doing this on the web.
thanks
arunb[/quote]
Regards, Andrew
dyeatman
PostPosted: Sat Nov 19, 2005 9:33 pm     Reply with quote
Try Google? Lots of stuff out there....
Here is the iSA pinout:
http://www.techfest.com/hardware/bus/isa.htm
Here are the ISA NE2000 connections:
http://www.edcheung.com/awards/pic2k/code.htm
Lots of NE2000 compatible cards easily available on Ebay. Just search for NE2000.
Mark
PostPosted: Sun Nov 20, 2005 10:31 am     Reply with quote
Just use the Microchip Ethernet chip ENC28J60. It is supposed to be in production this year. I had the guy in charge of the ENC28J60 visit me and I can't remember if he said Nov or Dec for production.
Don't want to wait, then here's one using the RTL8019AS
http://www.compsys1.com/workbench/uWEB/web_dev_board.html
