i2c And pic 16f88
uNO
i2c And pic 16f88
PostPosted: Fri Nov 18, 2005 2:13 pm     Reply with quote
Hi, I'm Trying to exchange data between two 16f88 connected on a i2c Bus.
To make a try I just used the two files Ex_slave.c and Ex_master.c. I've modified it only to configure them to use the 16f88.
I'use two pullup resitor (4,7k) on SDA and SCL
MASTER_SDA(B1)-----SLAVE_SDA(B1)------/\/\/\-----+5v
MASTER_SCL(B4)------SLAVE_SCL(B4)------/\/\/\------+5V
When I try to make it work I always read FF on the Emulated EEPROM (SLAVE PIC).Rolling Eyes
I've noticed that SCL is always LOW and SDA is always High but i can't guess why.
MASTER CODE
master.c
#include "master.h"
#include <input.c>
#include <2416.c>
void main() {
BYTE value, cmd;
EEPROM_ADDRESS address;
setup_oscillator(OSC_8MHZ | OSC_INTRC);
Then the code from ccs
ex_master.c
master.h
#include <16F88.h>
#fuses NOWDT,INTRC_IO, NOPUT, MCLR, BROWNOUT, LVP, NOCPD, NOWRT, NODEBUG, NOPROTECT, FCMEN, IESO
#use delay(clock=8000000)
#use rs232(baud=9600,parity=N,xmit=PIN_A0,rcv=PIN_A1,bits=8)
#use i2c(Master,sda=PIN_B1,scl=PIN_B4,force_hw,slow)
SLAVE CODE
slave.c
Ex_slave.c
slave.h
#include <16F88.h>
#use i2c(Slave,sda=PIN_B1,FORCE_HW,slow,scl=PIN_B4,address=0xa0)
In the laboratory where I'm working there is te version 3.236 of the compiler.
Please help me, I need it for an Experiment on artificial intelligence with the university.
Sorry for my very poor english.
Thank you
uNO
i2c
PostPosted: Sat Nov 19, 2005 7:56 am     Reply with quote
I made a mistake in my previous post , the file that I called EX_master.c is ex_extee.c.
I tried to use external clock, I'll get the output correctly on the screen via Serial port but always read FF on the emulated eprom.
I also tryed different values of pullìup resistor (4,7 | 1,8 | 2,3) but still nothing.
I'm quite sure that the circuit is well done, I've tryed some other code on the pic and all works great.
Please Help Me !!!
PostPosted: Sat Nov 19, 2005 12:47 pm     Reply with quote
First, here are some general comments:
1. Are you using a LVP programmer ? If not change the fuse to NOLVP
for each PIC.
2. You are using a software UART on both PICs. The 16F88 has a
hardware UART on pins RB5 and RB2 (Tx and Rx). If possible
you should use it instead of a soft UART.
With regard to fixing the problem:
I suggest that you first get it working with a real EEPROM chip as the
slave. This will prove that your master code is working. Then put
in the slave PIC and test it.
uNO
i2c
PostPosted: Sun Nov 20, 2005 6:53 pm     Reply with quote
Thank you PCM programmer, I removed the LVP flag.
I've found a solution, I've replaced the 4,7K with 10K pull-up resistors and used software i2c on the master
#include <16F88.h>
#fuses NOWDT,HS, NOPUT, MCLR, BROWNOUT, NOLVP, NOCPD, NOWRT, NODEBUG, NOPROTECT, FCMEN, IESO
#use i2c(Master,sda=PIN_B1,scl=PIN_B4,force_sw,FAST=80000)
Now all works greatly but i don't know why Rolling Eyes
