pic not sending to pc standalone |
Posted: Fri Nov 18, 2005 10:07 pm |
hi to all, pic is sending to pc ok if its working from my matrix multimedia
developer board, but if placed in a project board it does not work, checked
crystal and baud rates, are the same as using the matrix developer board,
am using a0 a1 as rx tx with a max232, crystal in board is 3276800 and it match #use delay, when pic is in project board i use a 4mhz then i specify this in use delay but doesnot work, it only works in my matrix board..
thanks |
Christian
Posted: Fri Nov 18, 2005 10:19 pm |
what fuses do you use?? |
Posted: Fri Nov 18, 2005 11:42 pm |
Quote: | crystal in board is 3276800 |
3.2768 MHz is a not a commonly used frequency.
It's available, but it's not very popular.
Are you sure that's the correct frequency ?
Is it possible that your crystal is really 32.768 KHz ? |
