recieve signal from two Rs232
PostPosted: Thu Nov 17, 2005 8:23 am     Reply with quote
Hey Guys
my question, as follows i m using a PIC16f877A on ACE board by CCS that the one which have 2 rs232 inputs,
i want to use both of them at the same time (i.e. receive and send to both of them)
how can i go about that ??
i will be sending characters to both (i.e. use putc())
can the compiler distinguish between both signals ..??
how can i declare #use rs232 for Two..??
how can i use putc() for two signals....?
do i have to set the receive and transmit for both to the same pin ??
i hope i made it clear
thank you in advance
dyeatman
PostPosted: Thu Nov 17, 2005 8:37 am     Reply with quote
There is lots of code here on this board about using two RS232 I/Os.
Use STREAMS (see #use RS232 in the manual) to differentiate between them.
Bart
PostPosted: Thu Nov 17, 2005 10:14 am     Reply with quote
1 of the 1000s examples : http://www.ccsinfo.com/forum/viewtopic.php?t=24716
greetings,
Bart
I like Skype (www.skype.com), my username is BplotM
