acid Guest
SIN() example |
Posted: Mon Jun 09, 2003 9:09 am |
Hello
Can Somebody tell me what is the "set_analog_voltage"?
This is an CCS's examples for SIN() :
Examples:
float phase;
// Output one sine wave
for(phase=0; phase<2*3.141596; phase+=0.01)
set_analog_voltage( sin(phase)+1 );
Thank in advance
Albert
___________________________
Original Post ID: 144515113 |
Re: SIN() example |
Posted: Mon Jun 09, 2003 12:48 pm |
:=Hello
:=Can Somebody tell me what is the "set_analog_voltage"?
:=This is an CCS's examples for SIN() :
What version of the compiler do you have ?
I looked in EX_SINE.C, and it doesn't have that code in it.
In fact, I can't find that code in any of the CCS example files.
I checked PCM versions 3.148 and 3.160.
Original Post ID: 144515121 |
acid Guest
Re: SIN() example |
Posted: Tue Jun 10, 2003 12:46 am |
:=:=Hello
:=:=Can Somebody tell me what is the "set_analog_voltage"?
:=:=This is an CCS's examples for SIN() :
:=What version of the compiler do you have ?
:=I looked in EX_SINE.C, and it doesn't have that code in it.
:=In fact, I can't find that code in any of the CCS example files.
:=I checked PCM versions 3.148 and 3.160.
I posted the help's page for sin(). My compiler is the 3.148 version and 3.126 IDE
ASIN()
ACOS()
ATAN()
SINH()
COSH()
TANH()
ATAN2()
Syntax:
val = sin (rad)
val = cos (rad)
val = tan (rad)
rad = asin (val)
rad1 = acos (val)
rad = atan (val)
rad2=atan2(val, val)
result=sinh(value)
result=cosh(value)
result=tanh(value)
Parameters:
rad is a float representing an angle in Radians -2pi to 2pi. val is a float with the range -1.0 to 1.0. Value is a float.
Returns:
rad is a float representing an angle in Radians -pi/2 to pi/2
rad1 is a float representing an angle in Radians 0 to pi
rad2 is a float representing an angle in Radians -pi to pi
Result is a float
Function:
These functions perform basic Trigonometric functions.
sin
returns the sine value of the parameter (measured in radians)
cos
returns the cosine value of the parameter (measured in radians)
tan
returns the tangent value of the parameter (measured in radians)
asin
returns the arc sine value in the range [-pi/2,+pi/2] radians
acos
returns the arc cosine value in the range[0,pi] radians
atan
returns the arc tangent value in the range [-pi/2,+pi/2] radians
atan2
returns the arc tangent of y/x in the range [-pi,+pi] radians
sinh
returns the hyperbolic sine of x
cosh
returns the hyperbolic cosine of x
tanh
returns the hyperbolic tangent of x
Note on error handling:
If "errno.h" is included then the domain and range errors are stored in the errno variable. The user can check the errno to see if an error has occurred and print the error using the perror function.
Domain error occurs in the following cases:
asin: when the argument not in the range[-1,+1]
acos: when the argument not in the range[-1,+1]
atan2: when both arguments are zero
Range error occur in the following cases:
cosh: when the argument is too large
sinh: when the argument is too large
Availability:
All devices
Requires
math.h must be included.
Examples:
float phase;
Example Files:
ex_tank.c
Also See:
log(), log10(), exp(), pow(), sqrt()
Original Post ID: 144515133 |
R.J.Hamlett Guest
Re: SIN() example |
Posted: Tue Jun 10, 2003 2:00 am |
:=:=:=Hello
:=:=:=Can Somebody tell me what is the "set_analog_voltage"?
:=:=:=This is an CCS's examples for SIN() :
:=:=What version of the compiler do you have ?
:=:=I looked in EX_SINE.C, and it doesn't have that code in it.
:=:=In fact, I can't find that code in any of the CCS example files.
:=:=I checked PCM versions 3.148 and 3.160.
:=Hello,
:=I posted the help's page for sin(). My compiler is the 3.148 version and 3.126 IDE
:=Thanks
:=ASIN()
:=ACOS()
:=ATAN()
:=SINH()
:=COSH()
:=TANH()
:=ATAN2()
:=Syntax:
:= val = sin (rad)
:=val = cos (rad)
:=val = tan (rad)
:=rad = asin (val)
:=rad1 = acos (val)
:=rad = atan (val)
:=rad2=atan2(val, val)
:=result=sinh(value)
:=result=cosh(value)
:=result=tanh(value)
:=Parameters:
:= rad is a float representing an angle in Radians -2pi to 2pi. val is a float with the range -1.0 to 1.0. Value is a float.
:=Returns:
:= rad is a float representing an angle in Radians -pi/2 to pi/2
:=val is a float with the range -1.0 to 1.0.
:=rad1 is a float representing an angle in Radians 0 to pi
:=rad2 is a float representing an angle in Radians -pi to pi
:=Result is a float
:=Function:
:= These functions perform basic Trigonometric functions.
:=sin
:= returns the sine value of the parameter (measured in radians)
:=cos
:= returns the cosine value of the parameter (measured in radians)
:=tan
:= returns the tangent value of the parameter (measured in radians)
:=asin
:= returns the arc sine value in the range [-pi/2,+pi/2] radians
:=acos
:= returns the arc cosine value in the range[0,pi] radians
:=atan
:= returns the arc tangent value in the range [-pi/2,+pi/2] radians
:=atan2
:= returns the arc tangent of y/x in the range [-pi,+pi] radians
:=sinh
:= returns the hyperbolic sine of x
:=cosh
:= returns the hyperbolic cosine of x
:=tanh
:= returns the hyperbolic tangent of x
:=Note on error handling:
:=If "errno.h" is included then the domain and range errors are stored in the errno variable. The user can check the errno to see if an error has occurred and print the error using the perror function.
:=Domain error occurs in the following cases:
:=asin: when the argument not in the range[-1,+1]
:=acos: when the argument not in the range[-1,+1]
:=atan2: when both arguments are zero
:=Range error occur in the following cases:
:=cosh: when the argument is too large
:=sinh: when the argument is too large
:=Availability:
:= All devices
:=Requires
:= math.h must be included.
:=Examples:
:= float phase;
:=// Output one sine wave
:=for(phase=0; phase<2*3.141596; phase+=0.01)
:= set_analog_voltage( sin(phase)+1 );
:=Example Files:
:= ex_tank.c
:=Also See:
:= log(), log10(), exp(), pow(), sqrt()
OK. This is a classic 'example'. It is just showing you a typical 'use' of the code. As such the other function (set_analog_voltage), doesn't exist in the compiler, but is (by it's name), meant to give you an idea of how to use the trig function.
What is being shown, is that if you wanted to output a sine wave, on a D-A converter, you would call the sin function, and send it's result to the D-A converter's 'output' function. Hence 'set_analog_voltage', is just meant to be a routine to set a D-A output value to the number given as an argument. This is a fairly common 'illustration' trick, where (for instance), if you wanted to show how to double an input voltage, you could give code like:
set_output_voltage(read_input_voltage() * 2);
It is 'meaningless' code in it's own right, but the idea is that readers should be able to understand the logic, for the function names.
So there is no 'set_analog_voltage' function, it is being used as an illustration.
Original Post ID: 144515135 |
acid Guest
Re: SIN() example..Thank |
Posted: Tue Jun 10, 2003 2:56 am |
:=:=:=:=Hello
:=:=:=:=Can Somebody tell me what is the "set_analog_voltage"?
:=:=:=:=This is an CCS's examples for SIN() :
:=:=:=What version of the compiler do you have ?
:=:=:=I looked in EX_SINE.C, and it doesn't have that code in it.
:=:=:=In fact, I can't find that code in any of the CCS example files.
:=:=:=I checked PCM versions 3.148 and 3.160.
:=:=Hello,
:=:=I posted the help's page for sin(). My compiler is the 3.148 version and 3.126 IDE
:=:=Thanks
:=:=ASIN()
:=:=ACOS()
:=:=ATAN()
:=:=SINH()
:=:=COSH()
:=:=TANH()
:=:=ATAN2()
:=:=Syntax:
:=:= val = sin (rad)
:=:=val = cos (rad)
:=:=val = tan (rad)
:=:=rad = asin (val)
:=:=rad1 = acos (val)
:=:=rad = atan (val)
:=:=rad2=atan2(val, val)
:=:=result=sinh(value)
:=:=result=cosh(value)
:=:=result=tanh(value)
:=:=Parameters:
:=:= rad is a float representing an angle in Radians -2pi to 2pi. val is a float with the range -1.0 to 1.0. Value is a float.
:=:=Returns:
:=:= rad is a float representing an angle in Radians -pi/2 to pi/2
:=:=val is a float with the range -1.0 to 1.0.
:=:=rad1 is a float representing an angle in Radians 0 to pi
:=:=rad2 is a float representing an angle in Radians -pi to pi
:=:=Result is a float
:=:=Function:
:=:= These functions perform basic Trigonometric functions.
:=:=sin
:=:= returns the sine value of the parameter (measured in radians)
:=:=cos
:=:= returns the cosine value of the parameter (measured in radians)
:=:=tan
:=:= returns the tangent value of the parameter (measured in radians)
:=:=asin
:=:= returns the arc sine value in the range [-pi/2,+pi/2] radians
:=:=acos
:=:= returns the arc cosine value in the range[0,pi] radians
:=:=atan
:=:= returns the arc tangent value in the range [-pi/2,+pi/2] radians
:=:=atan2
:=:= returns the arc tangent of y/x in the range [-pi,+pi] radians
:=:=sinh
:=:= returns the hyperbolic sine of x
:=:=cosh
:=:= returns the hyperbolic cosine of x
:=:=tanh
:=:= returns the hyperbolic tangent of x
:=:=Note on error handling:
:=:=If "errno.h" is included then the domain and range errors are stored in the errno variable. The user can check the errno to see if an error has occurred and print the error using the perror function.
:=:=Domain error occurs in the following cases:
:=:=asin: when the argument not in the range[-1,+1]
:=:=acos: when the argument not in the range[-1,+1]
:=:=atan2: when both arguments are zero
:=:=Range error occur in the following cases:
:=:=cosh: when the argument is too large
:=:=sinh: when the argument is too large
:=:=Availability:
:=:= All devices
:=:=Requires
:=:= math.h must be included.
:=:=Examples:
:=:= float phase;
:=:=// Output one sine wave
:=:=for(phase=0; phase<2*3.141596; phase+=0.01)
:=:= set_analog_voltage( sin(phase)+1 );
:=:=Example Files:
:=:= ex_tank.c
:=:=Also See:
:=:= log(), log10(), exp(), pow(), sqrt()
:=OK. This is a classic 'example'. It is just showing you a typical 'use' of the code. As such the other function (set_analog_voltage), doesn't exist in the compiler, but is (by it's name), meant to give you an idea of how to use the trig function.
:=What is being shown, is that if you wanted to output a sine wave, on a D-A converter, you would call the sin function, and send it's result to the D-A converter's 'output' function. Hence 'set_analog_voltage', is just meant to be a routine to set a D-A output value to the number given as an argument. This is a fairly common 'illustration' trick, where (for instance), if you wanted to show how to double an input voltage, you could give code like:
:=set_output_voltage(read_input_voltage() * 2);
:=It is 'meaningless' code in it's own right, but the idea is that readers should be able to understand the logic, for the function names.
:=So there is no 'set_analog_voltage' function, it is being used as an illustration.
:=Best Wishes
Original Post ID: 144515138 |
acid Guest
Posted: Tue Jun 10, 2003 2:57 am |
:=:=:=:=Hello
:=:=Hello,
:=:=Thanks
:=Best Wishes
Original Post ID: 144515139 |
