Two speed internal oscillator switching on PIC16F628A
SET
PostPosted: Tue Nov 15, 2005 7:59 am     Reply with quote
We have an application where the PIC needs to power up using the 31kHz internal oscillator, and then be put to sleep. When PIC wakes up, then the 4MHz internal oscillator is selected.
It appears that for this part that the CCS compiler must clear the OSCF bit in the PCON register to run at 4MHz (probably because we have declared '#use delay(clock=4000000)'). Is there any way to change this or just use '#use delay(clock=31250)' and '#use delay(clock=4000000)' before the relevant code areas?
BTW, setup_oscillator() is not recognised for this device. Compiler version is 3.190
Any thoughts?
Thanks!
PostPosted: Tue Nov 15, 2005 1:13 pm     Reply with quote
Here is a test program that shows how to switch the internal oscillator
frequency for your version of the compiler.
#include <16F628A.h>
#fuses INTRC_IO, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
#bit  OSCF = 0x8E.3        // PCON register
#define osc_4MHz()   OSCF = 1
#define osc_48KHz()  OSCF = 0
delay_ms(1);
// Switch to 48 KHz speed.
osc_48KHz();
#use delay(clock=48000)
delay_ms(1);
SET
PostPosted: Wed Nov 16, 2005 7:16 am     Reply with quote
Thats fine.. Smile but how do we ensure the compiler doesn't switch the PIC to 4MHz after reset? (which would take too much current in our application)?
I will do some testing and have a look at the code the compiler emits using different #use delay() statements.. will post the results later.
MikeValencia
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Wed Nov 16, 2005 7:37 am     Reply with quote
After reset, you should immediately switch to the lower frequency clock in your first few lines of code in main(), which of course gets executed following a reset.
As for #use delay statements, the code will follow the #use delay() statement immediately above it, so be careful where you physically type in your functions.
SET
PostPosted: Wed Nov 16, 2005 7:43 am     Reply with quote
Thanks Mike,
This looks like the way to do it - the micro will just have to take some current from the bypass capacitance until it does the oscillator mode switch!
I suppose Microchip made the 4MHz the default to avoid breaking older code.
Incidentally, the compiler doesn't seem to be generating any code that changes the OSCF bit - this ties in with other posts I checked about the #USE delay statement.
Thanks for the posts everyone!
Vic
