beth Guest
16F88 RS232 don't receive data. |
Posted: Tue Nov 15, 2005 3:14 am |
Hello everybody here, how are you? ;) I am looking for some "inspired" sould that can help me with this dissapointing problem :P.
I am not a begginer in the microcontrollers world, and this is getting me scary in some way, because the troubleshotting code is so easy and well, I will describe the problem.
I am working in a project that used a 16f628, and I decided to start with the new and more powerfull replacement in his category, the 16f88, and baby, after the switch I lose the rs232 communications.
I am using a max232 and is working ok, because I switch tx & rx to a 16f876 that is in the same protoboard, and works ok, (the circuit uses a 16f876 and a 16f88).
I can send data from the 16f88, but not receive that, but is so strange, the rx pin goes low all the time (in the 16f876 is high) and if I see the signal using a scope I see a 0v signal most of the time, except when I am sending data from the pc, in which case I see small variatons (the square wave) of 200 millivolts only. If I do the same test procedure in the 16f876 I see 5v most of the time in the rx line and goes to 0v when I am sending data from the pc.
I think that it must be a problem of the fuses, of the configuration, of my code or the compiler, I hope that the compiler does his work ok, but nowadays I did not trust in my shadow ;). This is my first attempt with a 16f88 and I don't know if I am configuring ok the system clock, the different options of the code, and maybe I am making a mistake, really I dont know what I am doing bad.
Here you have the code, its so simple because I started a new project for testing the communications, so please if someone can take a quick look and ... ;) :
(Thanks in advance, best wishes, and sorry for my bad english ;) )
(Compiler version 3.227)
[Module.h]
Code: | #include <16F88.h>
#device adc=8
#FUSES PUT //Power Up Timer
#FUSES NOFCMEN //Fail-safe clock monitor disabled
#use delay(clock=8000000)
#use rs232(baud=19200,parity=N,xmit=PIN_B5,rcv=PIN_B2,bits=8,stream=HW_RS232,errors)
[Module.c]
#include "Module.h"
int8 iChar='a';
int8 iRecv;
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
setup_oscillator(OSC_8MHZ|OSC_INTRC);
delay_ms( 100 );
fprintf( HW_RS232, "Starting ...\n\r" );
while ( 1 )
if ( kbhit( ) )
iRecv = fgetc( HW_RS232 );
fprintf( HW_RS232, "\n\rReceived: [ %c - %02X ] \n\r", iRecv, iRecv );
fprintf( HW_RS232, "%c", iChar++ );
delay_ms( 250 );
Posted: Tue Nov 15, 2005 5:29 am |
Try adding:
#bit B2TRIS=0x86.2
in the definitions,
Then after the initialisation, but before your first printf, add:
B2TRIS=1;
Unfortunately, some compiler versions, set the TRIS incorrectly for the receive pin, leaving it defined as an output, which then stops the data being received.
beth Guest
Heyyyy it worksssss. |
Posted: Tue Nov 15, 2005 10:37 am |
Ttelmah, thanks for your help, it works at the first try. There is a beer waiting for you here at Spain ;).
Again a lot of thanks. Best regards ;). |
Posted: Tue Nov 15, 2005 11:21 am |
Thanks.
Glad it worked. :-)
guest Guest
same problem |
Posted: Tue Aug 01, 2006 5:48 pm |
I have a similar problem. I can transmit data from the pic to the pc correctly. but when I try the reverse I can never get the pic to pause for my input.
I have verified the hardware using another compiler. (oshonsoft pic simulator)
Quote: |
Try adding:
#bit B2TRIS=0x86.2
in the definitions,
B2TRIS=1;
I tried this and I could not get any output from the pic. (I am using a 16F648A)
I only set up the serial port using #use_rs232. Do I add the B2TRIS=1 right at the begning of the program? |
