Need help rewriting a BS2 subroutine for PIC C
PostPosted: Sun Nov 13, 2005 2:58 pm     Reply with quote
I'm just starting to learn C, and I trying to do a project using an Ultralink WWVB receiver. I have some code for the Basic Stamp 2 that I'm trying to re-write in CCS C. The code I've translated seems to almost work, but not quite and I'm having trouble getting the functionality to match. Can someone take a look?
Basic Stamp Code:
DIAGNOSTIC_MODE:
SEROUT   TXpin,BAUD,[$02]      'execute diagnotic mode
TEMP_REG = 0            'counting register is reset to zero
Read_Mode:
DEBUG   "COUNT = ",DEC TEMP_REG,CR   'display count
SERIN   RXpin,BAUD,2000,no_response2,[DAT1]
IF   DAT1 <> %00000011 THEN Increase_Count   'see if diagnostic mode returns a '03'hex
TEMP_REG = 0            'if a '03'hex is returned then reset counter
HIGH   DatBad            'light no signal lock LED
LOW   DatGood            'extinguish signal lock LED
GOTO   Read_Mode            'continue checking
Increase_Count:
TEMP_REG = TEMP_REG + 1         'increment count of "good" responses
If TEMP_REG < 60 THEN Read_Mode   'after a minute of "good" responses
HIGH   DatGood            'consider the receiver locked
LOW   DatBad            'set LEDs to display data as valid
RETURN
no_response2:
GOTO DIAGNOSTIC_MODE
END:
My code:
Void Diagnostic_Mode()
        Byte Temp_Reg;          //counting/working register
        Byte Data;              //data received in diagnostic mode
        Temp_Reg = 0;           // counting register is reset to zero
        fputc(0x02, Clock);           // '02' hex puts decoder in diagnotic mode
        do      //reading mode
                do
                        Data=fgetc(Clock);
                        printf(lcd_putc,"\fData = %u\n",Data);
                        Output_high(DataBad);                   //light no signal lock LED
                        Output_low(DataGood);                   //extinguish signal lock LED
                        Temp_Reg = 0;
                while (Data != 0b00000011);
                Temp_Reg++;
                lcd_putc(" \fEnd Mode\n");
                Output_high(DataGood);                  'consider the receiver locked
                Output_low(DataBad);                    'set LEDs to display data as valid
        while (Temp_Reg < 60);
        return;
Argh!! I don't seem to get how to make the code work the same way given the lack of "Go to" in C........
Oh, BTW, once the module is put in "diagnostic mode" it send a status byte each second. The byte can be 0, 1, 2 or 3. If it's 3 the reply is not "good", everything else indicates a "good" response. One minute of "good" is supposed to signify that the clock is locked on the time signal.
Thanks!
Bob
asmallri
PostPosted: Sun Nov 13, 2005 5:21 pm     Reply with quote
   Byte Temp_Reg = 0;     //counting/working register  is reset to zero
   while(1)      //reading mode
      Data=fgetc(Clock);
      if (Data != 0b00000011)
         Temp_Reg++;
         if (Temp_Reg >= 60)
            Output_high(DataGood);           //consider the receiver locked
            Output_low(DataBad);              // set LEDs to display data as valid
            return;
         Temp_Reg = 0;
Regards, Andrew
