specialk
PIC18F2550 USB serial corruption |
Posted: Sat Nov 12, 2005 4:34 pm |
I'm having some trouble with a program that I've tried to convert from RS232 to USB. The program works perfectly when the chip is connected to a serial port; however, when sending data using USB, the output is less than ideal.
I adopted the USB code from the serial2 example and everything related to connecting and recognizing the chip as an emulated RS232 port work fine. I have the USB connected to the PIC with a connection sense pin. I also have a 220nF capacitor on Vusb as the datasheet recommends. The problem is that while it sends data to the terminal program at a relatively consistent rate, the PIC seems to send a garbled character every few seconds at an inconsistent rate. When I do the "r" command and read the data back from the EEPROM, everything goes haywire and it rarely gets past 500 outputs (the PIC either freezes up or it just breaks out of the loop somehow and resumes the outputs in the main do loop.
I've tried a larger Vusb capacitor and I've also tried inserting waits in between the printf's to give the USB module time to send the data; however, nothing is solving the problem (although the waits help cut down the frequency, the corruption is happening at a completely unacceptable level). Any suggestions would be greatly appreciated!
Compiler Version: 3.235
Target PIC Microcontroller: PIC18F2550
Standard Run Mode
Target voltage: 5V
Target oscillator speed, type: 20MHz resonator PLL & div to 48MHz
Code: | #include <18F2550.h>
//configure a 20MHz crystal to operate at 48MHz
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#use delay(clock=48000000)
#use rs232(stream=PC, baud=115200, parity=N, bits=8, xmit=PIN_C6, rcv=PIN_C7)
#use i2c(master,sda=PIN_B1,scl=PIN_B0)
#build(reset=0x1, interrupt=0x5) // Necessary for Bootloader
#ORG 0x0F00,0x0FFF {} // Necessary for Bootloader
#define DQ PIN_B7 // 1-Wire pin assignment
output_float(DQ); // Make sure to have a 4k7 pullup on bus
#define LEDmeasurement PIN_B6 // Measurement LED pin assignment
output_high(LEDmeasurement); // Initially makes Measurement LED high
#define USB_CON_SENSE_PIN PIN_B2
#define __USB_PIC_PERIF__ 1 // Set to 1 to use a PIC18 internal USB
#include <24256.c> // Include 24LC256 EEPROM Library
#include <1wire.h> // Include the 1-Wire Library
#include <usb_cdc.h> //USB code and interrupts & CDC API
//#rom int 0xf00000={1,2,3,4}
const int16 maxRecordLength = (16383*2) + 2; // Maximum for 24LC256 is 32768
// First two bytes are for app use
int8 scratch[9]; // Lowest 2 bytes are for temp
int8 uReceive; // Temporary byte for USART receive
int8 loggingDelay; // Logging Delay in seconds
int8 theFamily; // The 1-wire device family code
int16 curAddress; // Address to write the next reading
void getScratchpad() {
int8 i;
ow_reset(); // Reset the 1-wire bus, check presence
ow_write_byte(0xCC); // Skip ROM command
ow_write_byte(0x44); // Temperature convert command
output_float(DQ); // Strong pull-up for conversion
delay_ms(750); // Max. time for conversion is 750mS
ow_write_byte(0xBE); // Read Scratch Pad command
dowcrc = 0; // Reset the crc to start a new calc.
for (i=0;i<=7;i++)
scratch[i] = ow_read_byte(); // Read each scratchpad byte
ow_crc(scratch[i]); // Accumulate the CRC
scratch[8] = ow_read_byte(); // Receive CRC byte
void readUSBData()
int16 i;
int8 n;
uReceive = usb_cdc_getc();
printf(usb_cdc_putc, "\n\r\n\r");
switch (uReceive) {
case '?': {
printf(usb_cdc_putc, "Commands (note: all lowercase):\n\r");
printf(usb_cdc_putc, " c = Echo counter value\n\r");
printf(usb_cdc_putc, " f = Echo family code\n\r");
printf(usb_cdc_putc, " t = Change timing interval\n\r");
printf(usb_cdc_putc, " r = Read back data from EEPROM\n\r");
printf(usb_cdc_putc, " u = Reset counter");
case 'c': printf(usb_cdc_putc, "Counter: %lu", curAddress/2);
case 'f': {
theFamily = ow_familyCode();
switch (theFamily)
case 0x10: printf(usb_cdc_putc, "DS1820/DS18S20 Connected"); // DS1820
case 0x22: printf(usb_cdc_putc, "DS1822 Connected"); // DS1822
case 0x28: printf(usb_cdc_putc, "DS18B20 Connected"); // DS18B20
default : printf(usb_cdc_putc, "Unknown"); // Unknown Family
printf(usb_cdc_putc, "\n\rFamily Code: 0x%X", theFamily);
case 't': {
printf(usb_cdc_putc, "Please select logging interval:\n\r");
printf(usb_cdc_putc, " 1 = 1 second\n\r");
printf(usb_cdc_putc, " 2 = 2 seconds\n\r");
printf(usb_cdc_putc, " 3 = 5 seconds\n\r");
printf(usb_cdc_putc, " 4 = 10 seconds\n\r");
printf(usb_cdc_putc, " 5 = 15 seconds\n\r");
printf(usb_cdc_putc, " 6 = 30 seconds\n\r");
printf(usb_cdc_putc, " 7 = 1 minute\n\r");
printf(usb_cdc_putc, " 8 = 2 minutes\n\r");
printf(usb_cdc_putc, " 9 = 4 minutes\n\r");
switch (uReceive) {
case '1': write_ext_eeprom(0,1); // Write 1 second
case '2': write_ext_eeprom(0,2); // Write 2 seconds
case '3': write_ext_eeprom(0,5); // Write 5 seconds
case '4': write_ext_eeprom(0,10); // Write 10 seconds
case '5': write_ext_eeprom(0,15); // Write 15 seconds
case '6': write_ext_eeprom(0,30); // Write 30 seconds
case '7': write_ext_eeprom(0,60); // Write 60 seconds
case '8': write_ext_eeprom(0,120); // Write 120 seconds
case '9': write_ext_eeprom(0,240); // Write 240 seconds
default: write_ext_eeprom(0,5); // Write 5 seconds if unknown
loggingDelay = read_ext_eeprom(0);
case 'r': {
printf(usb_cdc_putc, "\n\r");
i=2; // 0,1 are reserved for program
do {
printf(usb_cdc_putc, "%lu,", i/2); // Print the index
delay_ms(1);
printf(usb_cdc_putc, "%u,", read_ext_eeprom(i)); // Print the MSB
delay_ms(1);
++i; // Increment Read Address
printf(usb_cdc_putc, "%u\n\r", read_ext_eeprom(i)); // Print the LSB
delay_ms(1);
} while (i<maxRecordLength);
case 'u': {
curAddress = 2; // Reset
printf(usb_cdc_putc, "Counter has been reset");
default: printf(usb_cdc_putc, "Unknown command (type ? for available commands)");
printf("\n\r");
void main() {
int8 i;
int8 tempT;
int16 stemp16, tempDecimal;
SETUP_ADC_PORTS(NO_ANALOGS); // Turn off the ADC ports
SETUP_ADC(ADC_OFF); // Turn off the ADC
SETUP_TIMER_0(RTCC_INTERNAL|RTCC_DIV_1); // Use the int. osc. for Timer 0
SETUP_TIMER_1(T1_DISABLED); // Disable Timer 1
SETUP_TIMER_2(T2_DIV_BY_1, 127, 1);
SETUP_TIMER_3(T3_DISABLED); // Disable Timer 3
SETUP_CCP1(CCP_OFF);
SETUP_CCP2(CCP_OFF);
usb_init();
while(!usb_cdc_connected()) {}
init_ext_eeprom(); // Initialize the EEPROM
loggingDelay = read_ext_eeprom(0); // Read the Logging Delay
theFamily = ow_familyCode(); // Read the Family Code
curAddress = 2;
loggingDelay = 1;
getScratchpad();
if (scratch[8] == dowcrc & scratch[4] != 0x7F & (theFamily == 0x22 | theFamily == 0x28))
ow_write_byte(0x4E); // Write Scratchpad command
ow_write_byte(scratch[2]); // Write TH
ow_write_byte(scratch[3]); // Write TL
ow_write_byte(0x7F); // Write Config (12-bit temp)
printf(usb_cdc_putc, "\n\rSet sensor to 12-bit mode\n\r");
printf(usb_cdc_putc, "\n\r\n\rOK\n\r"); // Everything started up ok
do {
if (usb_cdc_kbhit()) readUSBData();
getScratchpad();
if (scratch[8] == dowcrc) // If the CRC is OK then...
printf(usb_cdc_putc, "%u,", scratch[1]); // Print the MSB
printf(usb_cdc_putc, "%u\n\r", scratch[0]); // Print the LSB
Output_Toggle(LEDmeasurement);
printf("%u,", 0xFF); // Print 0xFF
printf("%u\n\r", 0xFF); // Print 0xFF
delay_ms(250); // Delay for 250 ms
for (i=1;i<=loggingDelay-1;++i) // If loggingDelay > 1 sec, delay (loggingDelay - 1 sec)
} while (TRUE);
-special [k] |
specialk
Posted: Sat Nov 12, 2005 5:08 pm |
Just for some examples of the corruption:
When it is running normally:
Code: | ...
1,109
1,110
1,110
1,110
1,110
1,11 <- Corruption
1,110
1,110
1,110
1,111
1,110
Code: | ...
1,113
1,113
1,113
1,113
1,113
1,43 <- Corruption
1,113
1,114
1,113
1,114
1,114
Code: | ...
1,115
1,115
1,115
1,115
1,115
1,10? <- Corruption
1,115
1,116
1,115
1,116
1,116
When "r" is pressed to read back EEPROM values:
Code: | ...
374,1,47
375,1,47
376,1,47
37781a12aіʍ7.522201215211`MKHjE1$B0t@1܊}82yE2|QHGQRP112j021151Q袆Qt0pȱp`d;qǀb9mVCCUWEep`wP0n9QpA|ذ}1aP |CƁ3LDY<TsZ0s_]`xk6uF{:iBi%@|C9Z1,47
378,1,47
379,1,47
380,1,47
381,1,47
382,1,47
383,1,47
384,1,47
385,1,47
38681a12aіʍ7.522201215211`MKHjE1$B0t@1܊}82yE2|QHGQRP112j021151Q袆Qt0pȱp`d;qǀb9mVCCUWEep`wP0n9QpA|ذ}1aP |CƁ3LDY<TsZ0s_]`xk6uF{:iBi%@|C9Z387,1,47
388,1,47
389,1,47
390,1,47
391,1,47
392,1,47
393,1,47
394,1,47
395,1,47
396,1,48
406,1,47
407,1,48
408,1,47
409,1,47
410,1,47411,1,47
412,1,47
413,1,47
414,1,47
415,1,47
-special [k] |
Darren Rook
Joined: 06 Sep 2003 Posts: 287 Location: Milwaukee, WI
Posted: Sat Nov 12, 2005 10:05 pm |
Recently (like last week) there was some updates to the CDC driver. What is the last date it says in the version history of the CDC driver? |
specialk
Posted: Sun Nov 13, 2005 2:30 pm |
Darren Rook wrote: | Recently (like last week) there was some updates to the CDC driver. What is the last date it says in the version history of the CDC driver? |
Code: | ///////////////////////////////////////////////////////////////////////////
//// usb_desc_cdc.h ////
//// An example set of device / configuration descriptors for use with ////
//// CCS's CDC Virtual COM Port driver (see usb_cdc.h) ////
//// Two examples are provided: ////
//// ex_usb_serial.c ////
//// ex_usb_serial2.c ////
//// Version History: ////
So I guess I have the older version... Is it a simple fix for the CDC issue?
-special [k] |
specialk
Posted: Mon Nov 14, 2005 6:41 pm |
specialk wrote: |
-special [k] | I'm guessing that it isn't??
-special [k] |
