When my program is running the D4 bit (C4 of the pic) is being held high.
So when i ask to print a "C" i get an "S" ect. The lcd is intilizing properly (or seems to be) and the other bits look fine. When the program does a read from the lcd the C4 bit follows as a input but when it configures as an out put (tris c) it goes high and stays high.
I am using the LCD driver configured for port C. The pic is running at 31KHz (int osc) and my compiler is version 3.228.
I have run the code on Mtlabs sim and it looks like it should work.
Any help would be greatly appr.
Posted: Fri Nov 11, 2005 6:06 pm
In your version of the compiler, CCS has some incorrect initialization
code which turns on comparator #2 by mistake. To fix this problem,
you need to add the line of code shown below in bold:
setup_comparator(NC_NC_NC_NC); // Turn off comparators
