string concatenation!!! |
Posted: Fri Nov 11, 2005 3:55 am |
hi everyone.
im trying to produce a data string by first converting floats and integers into strings by using 'sprintf' command and then concatenating them to form the data string. But i dont get the correct output on the hyperterminal. can any one help, my code is as follows:
#include <16F877.h>
#device *=16
#include <stdlib.h>
#include <math.h>
#include <string.h>
#USE DELAY (CLOCK=4000000)
#fuses XT,NOWDT,NOLVP
#use rs232(baud=4800,xmit=pin_b1,rcv=pin_b2,parity=N,stream=pc)
char *combi3;
float no = 114.56;
int no2 = 102;
sprintf(marks,"%f",no);
sprintf(marks2,"%u",no2);
combi3 = strcat (marks,marks2);
fputs (combi3,pc);
Posted: Fri Nov 11, 2005 5:52 am |
Start by declaring some memory storage to actually hold the strings.
You don't show the declarations for 'marks', and 'marks2'. Remember that the storage must be large enough for the 'worst case' (including terminators. Also you'd probably be safer using a defined length for the %f statement.
So:
[code]
#include <16F877.h>
#device *=16
#include <stdlib.h>
#include <math.h>
#include <string.h>
char marks[20], marks2[10];
//Remember that 'marks, has to hold the complete string
char *combi3;
float no = 114.56;
int no2 = 102;
sprintf(marks,"%6.2f",no);
//Add a space here between the numbers
sprintf(marks2," %u",no2);
fputs (combi3,pc);
