MCLR_FROM_RUN why?
Hans Wedemeyer
MCLR_FROM_RUN why?
PostPosted: Mon Nov 07, 2005 6:01 pm     Reply with quote
One out of many units is rebooting sometimes.
n = restart_cause(); is returning 15 which means MCLR_FROM_RUN
Some thought on why one of many units does this, and the others never do it ?
The chip is a PIC18LF6720 (Silicon Rev A4) running at 3.3V. Supply is clean, MCLR is pulled up using a 22K. Units are tested at -40C up to +85C .
I'm starting to think this may be a bad chip, I'd appreciate some thoughts/opinions before I replace the chip..
Hans Wedemeyer
Re: MCLR_FROM_RUN. How to insert a NOP at 0000
PostPosted: Mon Nov 07, 2005 10:28 pm     Reply with quote
I checked the Errata sheet for rev. A4 and it appears the chip has a reset problem.
Changed the chip and the problem appears to be gone.
If this really is the issue, and it looks like it is, then Microchip has a work around:
Work around
Insert a NOP instruction at address 0x0000.
end Quote.
First two lines of code from my LST
0000: GOTO E482
0008: MOVFF FE8,05
Looks like CCS did not cater for the workaround!
So how do I insert a nop at location 0000 ?
hansw
PostPosted: Mon Nov 07, 2005 10:54 pm     Reply with quote
#include <18F6720.H>
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
#use delay (clock=4000000)
// Tell compiler to put reset code at address 0x0002,
// instead of at 0x0000, as is normally done.
#build(reset=0x0002)
#ROM 0 = {0xFFFF}     // Insert NOP at address 0
// Put interrupt service routines here.
Hans Wedemeyer
PostPosted: Tue Nov 08, 2005 8:19 am     Reply with quote
OK.... I think that did the trick.
Now the first line of the LST reads 0002: GOTO D5F8
Do I just assume an erased chip is full of NOP's ? or is there a way to "see" what's at location 0000 ?
Thanks for the help.
Best rgeards
Hans W
Mark
PostPosted: Tue Nov 08, 2005 8:59 am     Reply with quote
Yes, the erased chip would have nop's. Also, from MPLAB, you can view the program memory to verify that something not expected is sitting at location 0.
Hans Wedemeyer
PostPosted: Tue Nov 08, 2005 10:54 am     Reply with quote
Thanks....
