18f452 to 18f4520
Pota78
18f452 to 18f4520
PostPosted: Mon Nov 07, 2005 9:42 am     Reply with quote
Hi everyone, probably is a silly question, but I don't know how to solve this problem, I'm getting crazy...
I had a 18f452 and I have ever programmed it with ic-prog and a jdm-compatible programmer...
I have now a 18f4520... ic-prog does not program this device!!! what can I use to program this Pic?
Do you know if there is a schematic for a compatible programmer?
Thank you very much (and sorry for my bad english)
Pota
PostPosted: Mon Nov 07, 2005 4:38 pm     Reply with quote
I have now a 18f4520... ic-prog does not program this device.
This thread here,
http://www.ccsinfo.com/forum/viewtopic.php?t=24576
recommends this programmer software:
http://perso.wanadoo.es/siscobf/winpic800.htm
I have not tried it. Also the page has pop-up ads.
Bart
PostPosted: Mon Nov 07, 2005 4:45 pm     Reply with quote
I used ic-prog (with the 16F's) also but winpic800 is 3times beter, simply-er and faster.
Using it with a 18F4550 and selve build programmer jdm based.
I like Skype (www.skype.com), my username is BplotM
Pota78
PostPosted: Tue Nov 08, 2005 1:50 am     Reply with quote
Thank You very much, I tried to download winpic800 but the file I got is corrupted...
I found WinPicPr and it's very good (much more than ic-prog)... and I can use my jdm self-made programmer Smile
Can you post me a link to a functioning winpic800 installer?
Thank you again, Pota
Pota78
PostPosted: Tue Nov 08, 2005 1:53 am     Reply with quote
Ok, I downloaded another time the zip file and I was able to open it , thank you very much! Smile
