obi1 Guest
Problem with PIC12F683 |
Posted: Mon Nov 07, 2005 5:51 pm |
I'm having problem using PCWH Version 3.206 with PIC12F683. I'm doing a simple program to test the pic, but they are not working. Can anyone please tell me what is wrong with this code?
#include <12F683.h>
#device ADC=10//to define size of AD Channel
#fuses INTRC_IO, NOWDT,NOPROTECT,NOCPD,NOBROWNOUT,NOMCLR,NOPUT,NOIESO,NOFCMEN
//Setup Software serial communicationl
#use rs232(baud=9600, xmit=PIN_A5,BITS=8,INVERT)
void main(){
output_high(PIN_A2);
DELAY_MS(500);
output_low(PIN_A2);
DELAY_MS(500);
I'm sure that it's not the hardware problem. There is no output at Pin a2 at all. Please tell me how to fix this.
Thank you
Posted: Mon Nov 07, 2005 7:00 pm |
I'm doing a simple program to test the pic, but they are not working |
Your version of the compiler doesn't setup the i/o ports for digital i/o
correctly. To fix the problem, you need to add the lines shown in
bold below, to your program.
// Define register addresses so we can write to them directly.
#byte CMCON0 = 0x19
#byte ADCON0 = 0x1F
#byte ANSEL = 0x9F
CMCON0 = 7; // Turn off the comparators
ADCON0 = 0; // Set all i/o pins to digital
ANSEL = 0; // Turn off the A/D converter
DELAY_MS(500);
output_low(PIN_A2);
DELAY_MS(500);
obi Guest
Posted: Tue Nov 08, 2005 10:17 am |
Thank you for your help. It's working!!! |
