sizeof element in multi dimensional array
mds
PostPosted: Sun Nov 06, 2005 10:30 pm     Reply with quote
hi all
maybe doing something out of the ordinary here. I have a 2 dimensional array called pix map. the current contains only 3 but this will be expanded as new ones are added to the code.
so rather than write hard coded numbers in the prog. I wanted to use sizeof to find the sizes of the indexs in the array. My test print was
printf("%u,%u",sizeof(pix_map),sizeof(pix_map[1])
my results:
pix_map= 21 understandable but i expected 3
pix_map[1] =1 ?? I was hoping to see a 7
how do i find out how many elements in the 1st and 2nd indexs?
const byte pix_map[3][7]=
//uparrow
   {0b00000100,
    0b00001110,
    0b00010101,
    0b00000100,
    0b00000100,
    0b00000100,
    0b00000100},
//dwnarrow
   {0b00000100,
    0b00000100,
    0b00000100,
    0b00000100,
    0b00010101,
    0b00001110,
    0b00000100},
// box_on
   {0b00000000,
    0b00011111,
    0b00011111,
    0b00011111,
    0b00011111,
    0b00011111,
    0b00011111}
for(i=0;i<sizeof(pix_map);i++) //should be 3
   for(l=0;l<pix_map[1];l++) //should be 7
      fprintf(pc,"%X\n\r",pix_map[i][l]); ///test print--remove
      lcd_send_byte(1,pix_map[i][l]);           // write to CG ram area
   fprintf(pc,"\n\r"); //test print --remove
Mark
PostPosted: Sun Nov 06, 2005 10:48 pm     Reply with quote
Just use a #define instead of a number.
#define MAX_ELEMENTS        7
mds
PostPosted: Mon Nov 07, 2005 3:34 pm     Reply with quote
short n sweet thanks but not what i was after. I use that solution all the time.
I was hoping to learn that sizeof could better solve this situation for me.
Are you saying that sizeof is incapable of being used to find the size of the elements like this?
Mark
PostPosted: Mon Nov 07, 2005 3:36 pm     Reply with quote
Gives the number of bytes taken up by the array. Won't tell you anything about the number of elements.
PostPosted: Mon Nov 07, 2005 4:53 pm     Reply with quote
In order to make the sizeof operator work you can create a struct or typedef for the second dimension of your array.
typedef byte picture[7];
const picture pix_map[3]=
//uparrow
   {0b00000100,
    0b00001110,
    0b00010101,
    0b00000100,
    0b00000100,
    0b00000100,
    0b00000100},
//dwnarrow
   {0b00000100,
    0b00000100,
    0b00000100,
    0b00000100,
    0b00010101,
    0b00001110,
    0b00000100},
// box_on
   {0b00000000,
    0b00011111,
    0b00011111,
    0b00011111,
    0b00011111,
    0b00011111,
    0b00011111}
#define PICTURE_SIZE        (sizeof(picture))
#define NR_OF_PICS          (sizeof(pix_map) / PICTURE_SIZE)
Mark
PostPosted: Mon Nov 07, 2005 6:08 pm     Reply with quote
I took it that either array dimension may change.
mds
PostPosted: Mon Nov 07, 2005 11:56 pm     Reply with quote
thanks for clarifying the ins and outs of sizeof.
ill try both schemes and see which suits best
