gazalou Guest
Having troubles with printf |
Posted: Thu Nov 03, 2005 4:56 pm |
I have problem with printf. Can someone help me ?
here is the code :
const char hello_world[] = {"hello world"};
char ramstr[30];
printf ("hello world"); // that works
strcpy(ramstr,hello_world);
printf(ramstr); // that doesn't work
printf("%s",ramstr); // that doesn't work
memcpy(ramstr,hello_world,12);
Thank you.
Marc. |
Posted: Thu Nov 03, 2005 8:39 pm |
There are no pointers to constant strings in CCS.
The code below will work.
#include <16F877.H>
#use delay(clock = 4000000)
char ramstr[30];
strcpy(ramstr, "Hello World");
printf("%s", ramstr);
gazalou Guest
having trouble with printf |
Posted: Fri Nov 04, 2005 1:37 am |
thank you "PCM PROGRAMER"
but still doesn't work.
here is another working example :
i=1;
printf("hello world %d time",i);
I'm using PCH on a 18f8720 may i have trouble with string.h ? |
Foppie
Joined: 16 Sep 2005 Posts: 138 Location: The Netherlands
Re: having trouble with printf |
Posted: Fri Nov 04, 2005 2:11 am |
gazalou wrote: | I'm using PCH on a 18f8720 may I have trouble with string.h ? |
As far as I know, you don't need string.h for the code PCM prgogrammer gave you. He would have put it in his examplecode.
Instead of the const, can't you use a define? Code: | #include <16F877.H>
#define hello_world "Hello World!"
char ramstr[30];
printf(ramstr);
printf(ramstr);
Gazalou Guest
Problem with printf |
Posted: Mon Nov 07, 2005 10:03 am |
Still digging with my problem of printf.
When I use rs232 WITHOUT using enable pin
strcpy(ramstr,"hello world");
I get Two corrects "hello world".
When I use rs232 WITH using enable pin=G0 on 18f8720
I get only one "hello world" ( the first one ), and the final "d" of the second.
What I mean is that printf always sends the correct data ( checked on a oscilloscope) And the enable pin is correctly managed only with "immediate" strings ( Also checked on oscilloscope ).
I use serial #2 of the 18f8720 (rxd=pin_G2, txd=Pin_G1, enable=Pin_G0). other pins of port G aren't used.
Can someone help me ? |
Humberto
Posted: Mon Nov 07, 2005 2:48 pm |
Enable doesn´t have any conexion with the problem you mention, unless you are using RS485.
#use RS232 Option ENABLE means that the selected pin (PIN_G0) goes High during transmision only.
It is used to handle the Tx_Enable in RS485 transceivers.
Humberto |
Gazalou Guest
Posted: Mon Nov 07, 2005 3:24 pm |
Thanks Humberto,
But I'm using Rs485 !
What I wanted to say is that all the printf's go out from the tx pin but in some cases the enable pin seems not to work.
If I do printf(hello world") I can see the enable pin "enabling the rs-485 transceiver" for each character.
If I do printf("%s",memorystring) the enable pin won't work for all character.
regards |
