Need help for using pwm with pic 18f4431
lychek
PostPosted: Fri Nov 04, 2005 5:11 am     Reply with quote
I have PCH version 3.204 compiler, May i used this compiler version with setup power pwm or not?
I don't have a latest vesion of compiler, so i don't have a sample code to use pwm. If any one have a sample code to use pwm with pic18f4431, please provide me 1 copy.
Thank you.
PostPosted: Fri Nov 04, 2005 12:55 pm     Reply with quote
If your version of the compiler doesn't support the setup_power_pwm()
and associated functions, then you'll have to do it by writing directly to
the pwm registers. There is some code available in these threads:
http://www.ccsinfo.com/forum/viewtopic.php?t=21375
http://www.ccsinfo.com/forum/viewtopic.php?t=21455
