Simple LED loop
Dario
Simple LED loop
PostPosted: Thu Nov 03, 2005 2:22 pm     Reply with quote
For some reason the delay_ms does not seem to be working. I have the osc1 pin hooked to a function generator at 4 000 000Hz from 0-5V sin wave. afetr programming, the output pin A0 will pulse on for 600us and off for 200us. Could anyone tell me if there is something wrong with my code or if this is a sign that my programmer or CCS or MPLAB are not working properly. Thanks. Dario
#include <16F873A.h>
#device adc=8
#fuses NOWDT,HS, NOPUT, NOPROTECT, NODEBUG, BROWNOUT, LVP, NOCPD, NOWRT
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
set_tris_a(0x00);
output_high(PIN_A0);
delay_ms(1500);
output_low(PIN_A0);
jecottrell
PostPosted: Thu Nov 03, 2005 2:40 pm     Reply with quote
First suggestion will be to change LVP to NOLVP.
Experts will probably find more....
Good luck,
John
treitmey
PostPosted: Thu Nov 03, 2005 3:34 pm     Reply with quote
edited... nice catch cmdrdan. ???sin wave???
cmdrdan
Re: Simple LED loop
PostPosted: Thu Nov 03, 2005 3:46 pm     Reply with quote
Dario wrote:
For some reason the delay_ms does not seem to be working. I have the osc1 pin hooked to a function generator at 4 000 000Hz from 0-5V sin wave. }
What happens when you use a square wave instead of a sine wave??
Dario
Simple LED
PostPosted: Thu Nov 03, 2005 5:06 pm     Reply with quote
Changing to a square wave makes no differerence,
thanks for the advice.
neil
Round waves into square holes!!
PostPosted: Thu Nov 03, 2005 6:07 pm     Reply with quote
I was going to reply to this sooner, but got sidetracked...
Don't be misled by a sinewave seeming odd on a digital device. The CLKOUT pin drives the crystal with a (square?) wave to set it into oscillation, but the xtal 'rings' with a sinewave at its fundamental frequency. The xtal's oscillation is fed back into the CLKIN pin, which will be converted to a squarewave internally (probably by a schmitt trigger, I have not looked at the datasheet at this point!) to form the clock source for the pic. So, you have two options ,when specifying a xtal oscillator; you can use a crystal (or resonator) to self oscillate, or feed a logic level waveform into the CLKIN pin from a 'canned oscillator' or a signal generator, or anything you like and ignore the CLKOUT signal from the pic.
Because of the squaring done by the (schmitt?) you can probably feed in any periodic signal within the allowed thresholds and it will work as a reliable clock source.
asmallri
PostPosted: Thu Nov 03, 2005 6:55 pm     Reply with quote
Change the HS fuse to XT
Regards, Andrew
Dario
LEDs
PostPosted: Thu Nov 03, 2005 8:00 pm     Reply with quote
Thanks guys,
the NOLVP solution was it!!
Sin wave works fine.
jecottrell
PostPosted: Thu Nov 03, 2005 8:07 pm     Reply with quote
Very Happy
YES! Newbie, knucklehead gets one right!
Gloatingly,
John
