hyuga isao Guest
Warning 203 "test.c" Line 10(1,1): Condition alway |
Posted: Wed Jun 04, 2003 9:01 am |
Why!
Tell me.
#include <16F877.h>
#fuses
#use delay(CLOCK=20000000)
#fuses HS,WRT,NOPROTECT,NOWDT
#include <lcd.c>
main(){
while(1){
lcd_putc("message001");
Deleting intermediary files... done.
Executing: "C:\Program files\Picc\CCSC.exe" "test.c" +FM +DF +LN +T -A +M +Z +Y=9 +EA
>>> Warning 203 "test.c" Line 10(1,1): Condition always TRUE
Memory usage: ROM=3\% RAM=3\% - 9\%
0 Errors, 1 Warnings.
Loaded D:\test\test.cof
BUILD SUCCEEDED
___________________________
Original Post ID: 144515030 |
Tomi Guest
Re: Warning 203 "test.c" Line 10(1,1): Condition a |
Posted: Wed Jun 04, 2003 10:25 am |
:=Why!
:=Tell me.
Because "1" never becomes "0": while (1)
The TRUE state in C means "non zero".
:=#include <16F877.h>
:=#fuses
:=#use delay(CLOCK=20000000)
:=#fuses HS,WRT,NOPROTECT,NOWDT
:=#include <lcd.c>
:=main(){
:= lcd_init();
:=while(1){
:= lcd_putc("message001");
:= delay_ms(1000);
:=Deleting intermediary files... done.
:=Executing: "C:\Program files\Picc\CCSC.exe" "test.c" +FM +DF +LN +T -A +M +Z +Y=9 +EA
:=>>> Warning 203 "test.c" Line 10(1,1): Condition always TRUE
:= Memory usage: ROM=3\% RAM=3\% - 9\%
:= 0 Errors, 1 Warnings.
:=Loaded D:\test\test.cof
:=BUILD SUCCEEDED
Original Post ID: 144515031 |
Dave Yeatman Guest
Posted: Wed Jun 04, 2003 9:39 pm |
These are just typical precautionary warnings that many compilers issue to make sure you know this was done.
Notice it says "Build Succeeded" which means the program copiled normally.
Another warning you may see is one for unused variables (#202) which may or may not be handy for you. I use it when I am in the "clean up" stages, otherwise I keep it turned off.
To hide these messages put in a line near the top of the code like:
#IGNORE_WARNINGS 202, 203
// turn off Unused Variables (202)
// and Always True (203) warnings
Regards,
Dave
:=Why!
:=Tell me.
:=#fuses
:=#include <lcd.c>
:=main(){
:= lcd_init();
:=while(1){
:= delay_ms(1000);
:=BUILD SUCCEEDED
Original Post ID: 144515041 |
isao hyuga Guest
Posted: Thu Jun 05, 2003 7:56 am |
The problem was solved.
Thank you very much.
Original Post ID: 144515047 |
