How to use/declare the BYTE and BOOLEAN data types?
elliotg
PostPosted: Wed Nov 02, 2005 11:59 pm     Reply with quote
How do I use or declare the BYTE and BOOLEAN data types using PCW C Compiler? When I try to use them, the compiler complains that it is "expecting a , or )". Should these be standard data types? I don't see them in the help file, however, many of the examples supplied with the compiler utilize these types.
Foppie
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Thu Nov 03, 2005 1:20 am     Reply with quote
CCS does not know byte, instead use int or char for example. Boolean is also not known, use short or int1 instead.
There is a preprocessor directive #BYTE
Syntax: #byte id = x
Elements: id is a valid C identifier,
x is a C variable or a constant
Purpose: If the id is already known as a C variable then this will locate the variable at address x. In this case the variable type does not change from the original definition. If the id is not know a new C variable is created and placed at address x with the type int (8 bit).
Warning: In both cases memory at x is not exclusive to this variable. Other variables may be located at the same location. In fact when x is a variable then id and x share the same memory location.
There is also the option to define BYTE and BOOLEAN as follows:
#define BYTE int
#define BOOLEAN short
PostPosted: Thu Nov 03, 2005 1:22 am     Reply with quote
Look in the .H file for your PIC. The .H files are in the following folder:
C:\Program Files\Picc\Devices
Near the beginning of the .H file, you will see this:
#define BYTE int
#define BOOLEAN short int
Note that in CCS, an "int" is an 8-bit unsigned value.
A "short int" is a 1-bit value.
elliotg
PostPosted: Thu Nov 03, 2005 2:22 am     Reply with quote
Thanks for your prompt responses!
