Strange ADC behavior on PIC16F88
Futterama
PostPosted: Wed Nov 02, 2005 6:59 am     Reply with quote
Hello forum,
I'm using the ADC on PIC16F88 and it works fine. But, I don't get the same reading every time even though the voltage on the ADC input is exactly the same.
This is my code:
.h file:
#include <16F88.h>
#device adc=10
#fuses NOWDT,INTRC_IO, NOPUT, NOMCLR, BROWNOUT, NOLVP, NOCPD, NOWRT, NODEBUG, NOPROTECT, NOFCMEN, NOIESO
#use rs232(baud=9600,parity=N,xmit=PIN_B3,rcv=PIN_B5,bits=8,invert)
.c file:
#include "myfile.h"
   int16 i;
   setup_adc_ports(sAN0|VSS_VDD);
   setup_adc(ADC_CLOCK_DIV_8);
   setup_spi(FALSE);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   output_low(PIN_B3);
   delay_ms(2);
      i = read_adc();
      printf("%lu", i);
      putc(13);
      putc(10);
      delay_ms(10000);
The input of the ADC is connected to a resistor divider. The output from RS232 is like this:
886
877
886
877
886
877
... you get the point.
So, what the heck is going on? It's the same problem at different "update rates" (10000ms or 1000ms).
Hope you can help.
Regards,
Futterama
SherpaDoug
PostPosted: Wed Nov 02, 2005 7:22 am     Reply with quote
Try putting a cap, say 0.1 uF, from the A/D input to the A/D ground pin. Your resistor divider may have too high an impedance.
Futterama
PostPosted: Wed Nov 02, 2005 7:48 am     Reply with quote
The capacitor doesn't help.
I've changed the resistor divider to a 1k pot, and that doesn't help either.
I've changed to another PIC16F88, that doesn't help, so the PIC itself is fine.
It's always the same numbers coming out, even when changing PIC device.
I'm lost. What good is the ADC if it's faulty?
asmallri
PostPosted: Wed Nov 02, 2005 8:47 am     Reply with quote
You forgot to select the channel you want converted.
Regards, Andrew
gs
PostPosted: Wed Nov 02, 2005 12:22 pm     Reply with quote
measure the value 10 times in 1.5 ms intervals, Sum the results and divide by 10. This will give you a more stable value.
I use the following code in one of my projects. I also use RC filter (1K, 100nF) at the analog inputs
int16 mesi_timi()
   int16 value,sum;
   int   i;
   sum=0;
         for (i=1; i<=10; i++)
      value=Read_ADC();
      sum=sum+value;
      delay_us(1500);
    value=sum/10;
   return value;
www.hlektronika.gr
Futterama
PostPosted: Thu Nov 03, 2005 12:21 am     Reply with quote
That's right. But I guess since I use port 0 it doesn't matter, cause setting the port to 0 doesn't help.
int16 mesi_timi()
   int16 value,sum;
   int   i;
   sum=0;
      value=Read_ADC();
      sum=sum+value;
      delay_us(1500);
    value=sum/10;
   return value;
Well, yes, but I'll also get a very stable reading by only reading every second measurement (since they are the same).
As you can see, it can't be analog noise since the values are the same two repeating regardless of the convertion rate.
Futterama
PostPosted: Thu Nov 03, 2005 12:49 am     Reply with quote
DOH! I found the reason for my error.
My supply IC can deliver 40mA. I had a LED blinking every time a conversion was sent (I cut this part out of my posted code). The LED caused the voltage to drop a bit every time it was on. That's why I got these strange readings! Rolling Eyes
Thank you all - gs, I'll use your posted code to get stable readings, though I'll probably read 100 times instead of 10 Wink
Regards,
Futterama
PostPosted: Thu Nov 03, 2005 1:17 am     Reply with quote
Also, the capacitor does make a difference. Just now I was testing
your problem on a PicDem2-Plus, with a 16F88 and PCM vs. 3.235,
and I got this output:
Notice that it bounces around a little bit.
888
883
889
888
884
887
884
883
883
887
884
Then I added a 0.1 uF (i.e., 100 nF) capacitor close to the RA0 pin
and the GND pin on the 16F88. Then I got this output:
886
885
885
886
886
886
886
886
It's much more stable.
