defining length of array
dave the blade
PostPosted: Wed Nov 02, 2005 4:57 am     Reply with quote
Hi gents and ladies, ver 3.234, is there a way to define the length of an array to capture a_to_d readings after compilation of the program, in other words by entering a value from a keypad that tells the program the length of the array.
Cheers dave
MikeValencia
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Wed Nov 02, 2005 7:08 am     Reply with quote
I never tried it in the PIC environment, but i'll try to explain it the way i understand it to work:
Arrays are defined during compile-time, so you can't really define the length on-the-fly.
I think the solution you'd be looking for is to define a pointer to a char:
char *my_ptr;
Then you do a malloc() for the length you want.
e.g.
my_ptr = malloc(...);
After that, then you can address the contents accordingly via:
my_ptr[x] = 0x20; // for example
or
*(my_ptr + x) = 0x20;
I think the two statements above are equal, but I am not sure if CCS supports both.
OR
The easiest would be to just define an array of your worst-case longest length.
