Eeprom inserting data using #ROM
d00dajo
PostPosted: Thu Oct 27, 2005 11:22 am     Reply with quote
Hello everyone,
I have a question that is more MPLAB IDE related then CCS, but since all the competent people gather in this forum anyway, Ill give it a try on the message board.
I am trying to use the #ROM command to preset data in the eeprom. However, I have found something disturbing (disturbing because I cannot make sense out of it, but there is surely an explanation I just don't see it)
The hardware is a PIC 18F4680.
The eepromadress is located in 0xF0000-F003FF.
Now, the function works just fine. Data is inserted into the hexfile correctly and MPLAB updates the eeprom as it should.
But, when I examine the HEX-file I find NO difference between the format for the Flashdata at 0-3ff and the eeprom data at f0000-f003ff.
Example:
:1001900000F0A1BE04EF0BF00F50006E1050016E86 //This is FLASH data.
///LOTS OF LINES HERE////
:100190001800000000000000000000000000000047 //This is EEPROM data.
The lines start exactly the same?? Now, HOW can MPLAB know which line is eeprom and which is flash data? (I will be using the HEX file for purposes other than just programming the PIC, so I will need to know how to distinguish between the two)
//Daniel.
PostPosted: Thu Oct 27, 2005 11:38 am     Reply with quote
Compile a test program:
#include <18F4680.H>
#fuses XT, NOWDT, NOPROTECT,PUT,BROWNOUT,NOLVP
#ROM 0x300 = {1,2,3}
#ROM 0xF0300 = {4,5,6}
Here is the HEX file:
:020000040000FA
:1000000002EF00F0F86AD09EEA6AE96AC150C00BBC
:0C0010000F09C16E070EB46EFFD703008D
:06030000010002000300F1
:02000004000FEB
:06030000040005000600E8
:020000040030CA
:0E00000000011E1E008281000FC00FE00F40A5
:00000001FF
;PIC18F4680
Kiel has a good page on HEX files. Read the section
on Extended Linear Address Records.
http://www.keil.com/support/docs/1584.htm
d00dajo
PostPosted: Thu Oct 27, 2005 12:05 pm     Reply with quote
:020000040000FA
:02000004000FEB
:020000040030CA
:00000001FF
;PIC18F4680
Thanks PCM programmer,
I really did look at the 02 lines, but I looked at the first byte.
Of course the base adress is given in that record. Reading the textfile lineraly, the application will need to remember the last "base adress" set and calculate an offset.
//DJ
