pcmguy
internal eeprom problem |
Posted: Mon Oct 24, 2005 8:40 am |
Hi I'm trying to save and load eeprom data using 16f876, pcm 2.73, my program only works fine when I store data in eeprom less than 100, but when I use until 127 and 255 the pic hang.
As in datasheet, eeprom in 16f876 is 256 byte, so why it hang?
This is my source code:
#include<16f876.h>
#use delay (clock=20000000)
#fuses hs, noprotect, nolvp, nowdt
#byte portb=6
main()
byte i, mydata;
set_tris_b(0x00);
for(i=0; i<=50; i++)
{write_eeprom(i, i);}
{mydata=read_eeprom(i);
portb=mydata;
delay_ms(500);}
This program works fine, but when I change the 'i' limit to e.g. 127 or 255 the pic hang.
Please advice, thanks! |
Posted: Mon Oct 24, 2005 11:33 am |
It will hang if you set the limit value to 255, because "i" is in the
range of 0 to 255 and is always "less than or equal" to 255.
It will stay in the loop forever.
However, it shouldn't hang with a limit of 127.
Post the full version of your compiler. The version is not 2.73.
It will have three digits after the decimal point, like 2.730, 2.731, etc. |
