td Guest
preserve eeprom data |
Posted: Sun Oct 23, 2005 8:24 pm |
hello all, i wanted to know how i could preserve the eeprom data when i am reprogramming my pic18f252 microcontroller. i am using PICstartplus programmer with MPLAB. thanks much...
TD |
Mark
Posted: Mon Oct 24, 2005 6:58 am |
Uncheck the box that programs the eeprom  |
TD Guest
Posted: Mon Oct 24, 2005 1:57 pm |
thanks for your reply.
I unchecked the Program Data EEPROM and it works !
Okay this is what I followed. After enabling the programmer > Erase Flash Device > Program for downloading the 1st program
I wrote to the eeprom and checked it as well and it seems to be fine.
// would have received the characters to store in data eeprom from
// RS 232 input but here i am just showing some character
write_eeprom(20,'1');
write_eeprom(21,'5');
write_eeprom(22,'2');
write_eeprom(23,'5');
v1 = read_eeprom(20) - 0x30;
v2 = read_eeprom(21) - 0x30;
v3 = read_eeprom(22)- 0x30;
v4 = read_eeprom(23) - 0x30;
if( 1 == v1 && 5 == v2 && 2 == v3 && 5 == v4)
Output_high(Pin_C5);
Output_high(Pin_C3);
So the data eeprom at 20, 21, 22, 23 had '1,'5','2','5' since the proper LED was ON.
Now I reprogram the pic without erasing the eeprom. I compile/run the new code and then Enabled the programmer. And then clicked on Program/verify and unchecked DATA EEPROM > click program. thanks much
ps: I am sorry I posted this in another thread as well as part of another question[/code] |
TD Guest
Posted: Mon Oct 24, 2005 2:20 pm |
It does not work if I follow the procedure I had written in the above message. Please let me where I am making a mistake. |
