adding serial number problem
Atma
PostPosted: Sat Oct 22, 2005 7:01 am     Reply with quote
hi there
i am trying to add serial number to the program that i am writing. in the manual i came across
the following code:
int8 const serialNumA=100;
#serialize (id = serialNumA, next = "200", prompt = "Enter the serial number", log = "seriallog.txt")
but when i compile it, it gives me an error saying
invalid pre-processor directive.
so how exactly can i add a serial number?
I am using the PCW compiler.
thanks
PostPosted: Sat Oct 22, 2005 10:33 am     Reply with quote
Your version of the compiler probably doesn't support #serialize.
Here is the version when CCS added support:
3.162 Serial number support added and more advanced ICD.EXE is released
I compiled the following test program with PCH vs. 3.235, and it
compiled without error. (First, I had to take out all the spaces
that you had inserted after the equal signs and the commas.
It doesn't like those spaces).
#include <18F452.H>
#serialize (id=100,next="200",prompt="Enter the serial number",log="seriallog.txt")
Use the forum's search engine to search for: serial number
Here's one of the results:
http://www.ccsinfo.com/forum/viewtopic.php?t=22666&highlight=serial+number
Atma
PostPosted: Wed Nov 09, 2005 4:58 am     Reply with quote
hi there
I am using compiler version 3.148.
What i am doing is programming a PIC with another PIC and i have to add a serial number to the PIC. I have to add it from my GUI.
I tried using the #serialise stuff but i dont think that my compiler version supports it.
Is there anyway to store the serial number? would it work if i stored it in the ID locations? Does that mean i would have to write to the ID locations? If yes how can i do that?
Another thing is that is it possible to read back the serial number on the target device?
thanks in advance
Waiting in anticipation and hope.
Humberto
PostPosted: Wed Nov 09, 2005 9:18 am     Reply with quote
From CCS Compiler Version:
"3.162 Serial number support added and more advanced ICD.EXE is released"
Humberto
