18F2620 startup problem
salamander
PostPosted: Fri Oct 21, 2005 1:23 pm     Reply with quote
if got a custom board with an 18LF2620 mcu running at 3.3V.
Debugging and the communication to all components (like sensors, eeprom and rs232 transceiver) works very well. For the clock I use the internal Osc at 8Mhz.
But the target does not start if I try to use it without the debugger ( in debugging mode it works for hours without problems).
I tied MCLR with an 10k resistor (also tried 47k like suggested in the faq) to Vcc.
And when I disconnect the board from the ICD the debug wires are not longer than 1cm...
So any ideas what to do? I can not test my projekt in the real environment...
thanks a lot
salamander
my fuses (tried differnt, but probably I missed an important one..Smile
#FUSES HS //High speed Osc (> 4mhz)
#FUSES BORV21 //Brownout reset at 2.1V
#FUSES NOLVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
PostPosted: Fri Oct 21, 2005 1:31 pm     Reply with quote
Did you program the PIC with MPLAB in Programmer mode, instead
of Debugger mode ? You need to do that. See this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=21415
PostPosted: Fri Oct 21, 2005 4:09 pm     Reply with quote
tanks for your reply, but this is not the problem Smile
regards
salamander
PostPosted: Fri Oct 21, 2005 4:52 pm     Reply with quote
Post a very small test program that demonstrates the problem.
This could be simple LED blinking program. Make sure you
test this program in Debugger mode, and verify that it works,
and then test it in Programmer mode, and verify that it fails.
Then post it.
Also post the version of your compiler.
I want to look at your oscillator setup code. If I have your
version of the compiler, I'll check the .LST file to see if CCS
is creating the correct code.
PostPosted: Sat Oct 22, 2005 4:59 am     Reply with quote
it was my fault. Whem I disconnected the target from the debugger, I also removed the powersupply for the max3232 on my adapterboard. Just a silly layout problem:)
now it works just fine.
Thx a lot
salamander
