How to avoid Code, Table Write and Table Read Protect ???
moutinho
View user's profile Send private message Visit poster's website MSN Messenger
PostPosted: Fri Oct 21, 2005 12:47 pm     Reply with quote
I am developing using using MPLAB ICD2 and PIC18F8520. But I get the following message after downloading the software:
MPLAB ICD 2 Ready
Programming Target...
ICDWarn0042: Protect bit (CP_4 : Code Protect 10000-13FFF) is enabled. MPLAB ICD 2 will not enter debug mode in this configuration. Do you wish to disable this setting?
ICDWarn0042: Protect bit (CP_5 : Code Protect 14000-17FFF) is enabled. MPLAB ICD 2 will not enter debug mode in this configuration. Do you wish to disable this setting?
ICDWarn0042: Protect bit (CP_6 : Code Protect 18000-1BFFF) is enabled. MPLAB ICD 2 will not enter debug mode in this configuration. Do you wish to disable this setting?
ICDWarn0042: Protect bit (CP_7 : Code Protect 1C000-1FFFF) is enabled. MPLAB ICD 2 will not enter debug mode in this configuration. Do you wish to disable this setting?
ICDWarn0042: Protect bit (WRT_4 : Table Write Protect 10000-13FFF) is enabled. MPLAB ICD 2 will not enter debug mode in this configuration. Do you wish to disable this setting?
ICDWarn0042: Protect bit (WRT_5 : Table Write Protect 14000-17FFF) is enabled. MPLAB ICD 2 will not enter debug mode in this configuration. Do you wish to disable this setting?
ICDWarn0042: Protect bit (WRT_6 : Table Write Protect 18000-1BFFF) is enabled. MPLAB ICD 2 will not enter debug mode in this configuration. Do you wish to disable this setting?
ICDWarn0042: Protect bit (WRT_7 : Table Write Protect 1C000-1FFFF) is enabled. MPLAB ICD 2 will not enter debug mode in this configuration. Do you wish to disable this setting?
ICDWarn0042: Protect bit (EBTR_4 : Table Read Protect 10000-13FFF) is enabled. MPLAB ICD 2 will not enter debug mode in this configuration. Do you wish to disable this setting?
ICDWarn0042: Protect bit (EBTR_5 : Table Read Protect 14000-17FFF) is enabled. MPLAB ICD 2 will not enter debug mode in this configuration. Do you wish to disable this setting?
ICDWarn0042: Protect bit (EBTR_6 : Table Read Protect 18000-1BFFF) is enabled. MPLAB ICD 2 will not enter debug mode in this configuration. Do you wish to disable this setting?
ICDWarn0042: Protect bit (EBTR_7 : Table Read Protect 1C000-1FFFF) is enabled. MPLAB ICD 2 will not enter debug mode in this configuration. Do you wish to disable this setting?
...Erasing Part
How can I solve this?
Thanks,
Andre
PostPosted: Fri Oct 21, 2005 1:22 pm     Reply with quote
This is a pure ICD2 question, so you should ask it on the Microchip ICD2
forum. But first, use their search engine. Go to this link:
http://forum.microchip.com/search.asp
Set it for this:
Search Term: ICDWarn0042
Time Filter: All Topics
You will get about 10 hits on the topic.
