amcfall
12F683 questions, internal osc. and pullups |
Posted: Thu Oct 20, 2005 10:13 am |
Hello. I'm doing a simple project with a 12F683 and I'm having a few issues. Compiler is 3.203. First off, let me make sure I have my pin definitions correct.
PIC Ccs
GP0 PIN_A0
GP1 PIN_A1
GP2 PIN_A2
GP3 PIN_A3
GP4 PIN_A4
GP5 PIN_A5
1st problem is with the internal oscillator. I first tried INTRC_IO then INTRC, no luck. For some reason it only seems to work when I use RC.
Second issue is pullups. I have switches connected to pins 2 and 3 (GP4 and 5, which the DS says have individually programmable pullups). Perhaps I'm just doing something dumb? But this confused me (from page 156 of the manual):
PORT_A_PULLUPS
Availability: Only 14 and 16 bit devices (PCM and PCH). (Note: use
SETUP_COUNTERS on PCB parts).
Eh? What does setup_counters have to do with the pullups? Here's my test code:
#include <12F683.h>
#fuses NOWDT,RC, NOCPD, NOPROTECT, MCLR, NOPUT, BROWNOUT, IESO, FCMEN
#define downbutton PIN_A4
#define upbutton PIN_A5
setup_adc_ports(0);
setup_adc(ADC_OFF);
setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
set_tris_a(0b110000); //all outputs except A4 and A5
port_a_pullups(0b110000); //pullups on A4 and A5
setup_timer_2(T2_DIV_BY_1, 124, 1);
setup_ccp1(CCP_PWM);
set_pwm1_duty(10);
while (1)
Thanks in advance.
Avery
EDIT:
http://www.ccsinfo.com/forum/viewtopic.php?t=23063&highlight=12f683
explains some of the issue.
Just got the company CC, time to get the current ver of the 12F compiler.
Avery
Posted: Thu Oct 20, 2005 11:54 am |
Quote: | First off, let me make sure I have my pin definitions correct. |
They're correct.
Quote: | I first tried INTRC_IO then INTRC, no luck. For some reason it
only seems to work when I use RC. |
Make the changes shown in bold below.
#include <12F683.h>
#fuses NOWDT,INTRC_IO, NOCPD, NOPROTECT, MCLR, NOPUT, BROWNOUT, IESO, FCMEN
setup_oscillator(OSC_8MHZ);
Quote: |
(Note: use SETUP_COUNTERS on PCB parts).
What does setup_counters have to do with the pullups |
It applies only to the PCB compiler. You're using PCM, so ignore it. |
