mauro Guest
I2C built-in function is OK on 12c5x series???? |
Posted: Fri Dec 13, 2002 3:20 pm |
Sigh...please help me!!!
I'm new in pic programming, i'm not able to use write_ext_eeprom and read_ext_eeprom on my project using pic12c509a, the same projet compiled for 16f84 work right.
look a little portion of code.
#include "12c509a.h"
#include <2404.c>
// *************MAIN !!!!!!!!!!!!!!!!!!!!!!
void main(){
int x;
init_ext_eeprom();
x=5;
write_ext_eeprom(0,x);
Of course i have customized 2404.c file setting sda pinb5 and scl pinb4.
Please someone can help me????
___________________________
Original Post ID: 10042 |
R.J.Hamlett Guest
Re: I2C built-in function is OK on 12c5x series???? |
Posted: Fri Dec 13, 2002 3:39 pm |
:=Sigh...please help me!!!
:=I'm new in pic programming, i'm not able to use write_ext_eeprom and read_ext_eeprom on my project using pic12c509a, the same projet compiled for 16f84 work right.
:=look a little portion of code.
:=#include "12c509a.h"
:=#use delay(clock=4000000)
:=#include <2404.c>
:=// *************MAIN !!!!!!!!!!!!!!!!!!!!!!
:=void main(){
:=int x;
:= init_ext_eeprom();
:=x=5;
:= write_ext_eeprom(0,x);
:=Of course i have customized 2404.c file setting sda pinb5 and scl pinb4.
:=Please someone can help me????
Obvious questions, are what configuration settings are you using?. This will only work on b4, and b5, with the INTRC setting, and only with B4, set as I/O, not OSC2. By default the configuration for a 12C671 (which I use more than the 509), if set to 'INTRC', sets the chip up with B4 set as OSC2. If this was happening, the interface wouldn't work, because there would be the processor clock on this pin, rather than the required data!.
Check in your programmer that the bits are set correctly.
Original Post ID: 10044 |
neil
Posted: Sun Dec 15, 2002 6:09 am |
Hi, Can I just add that your main() function does not have a loop in it. After the write_ext_eeprom line, you should add a 'while(TRUE) {}' so that when the last instruction has been executed, the processor loops forever. If this is not present, the processor (I think) will run off the end of the code into unprogrammed ROM space and just keep wrapping around to the beginning. You would probably see an effect like the PIC keeping resetting itself.
Also, just mentioning this in case you forgot... Do you have pullup resistors on your SDA and SCL lines? The best values to use is 1K - 2.2K. The internal port B pullups on the PIC (if configured) are too high a resistance to be effective with I²C.
:=#include <2404.c>
:=void main(){
:=int x;
:=x=5;
Original Post ID: 10048 |
