Convert binary value to decimal
bigoune
PostPosted: Wed Oct 19, 2005 10:10 am     Reply with quote
I would like to convert binary value to decimal value. Do you know a function in CCS to realize this operation?
Thank you
Humberto
PostPosted: Wed Oct 19, 2005 10:21 am     Reply with quote
Use the Search feature of this forum and write the magic word "BCD", youŽll get
a lot of threads to read and learn how to.
Humberto
MikeValencia
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Wed Oct 19, 2005 8:48 pm     Reply with quote
I would consult the 1st chapter in your introductory course to Digital Logic where they teach binary and decimal. Idea
Mark
Re: Convert binary value to decimal
PostPosted: Thu Oct 20, 2005 6:48 am     Reply with quote
bigoune wrote:
Thank you
Are you saying that you want to convert a string that is a representation of a binary number into an integer?
TIMT
binary to decimal
PostPosted: Thu Oct 20, 2005 8:23 am     Reply with quote
Hi there I've attached some code done at home for converting the 10 bit binary code from the D to A in the pic to a decimal float. It will display the voltage on an lcd or whatever printf is. I wrote it for a 3volt full scale deflection. e.g 1111111111000000 (65472 in decimal) in long integer value (read from the a to d) represents 3volts... 65472/3 is 21824.
It works ok for me. My maths is not that good though so if there is a problem with it I deny all knowledge ! if it helps, use it
Tim
void dis_3v0_fsd(long int value)   // Function for sending voltage to LCD, 10 bit, 3.0V FSD.
       float disval;
       disval = value;
       disval = disval/21824;
       printf(lcd_putc,"%4.2fV",disval);
Tim
