#fuses options definition
Alvin
PostPosted: Wed Oct 19, 2005 10:41 am     Reply with quote
Hi, can someone help me find descriptions for the options when using #fuses.
for example, what is BORV45?
PostPosted: Wed Oct 19, 2005 12:56 pm     Reply with quote
what is BORV45?
It's CCS's symbolic name for the last Brown-Out voltage setting
in the chart below:
bit 3-2 BORV1:BORV0: Brown-out Reset Voltage bits
11 = VBOR set to 2.5V
10 = VBOR set to 2.7V
01 = VBOR set to 4.2V
00 = VBOR set to 4.5V
The following two threads will provide more information:
http://www.ccsinfo.com/forum/viewtopic.php?t=22297
http://www.ccsinfo.com/forum/viewtopic.php?t=24336
Alvin
#fuses
PostPosted: Fri Oct 21, 2005 12:25 pm     Reply with quote
Thanks for posting the link. It was really helpful. I originally had problems re-flashing a PIC. It was because i used the #fuse NOMCLR. I changed it to #fuse MCLR, that was the fix.
