square wave input to pic!!!
ambivalent
PostPosted: Sat Oct 15, 2005 4:06 am     Reply with quote
hi everyone.
i want to apply a square wave input (0 -> 12v) to PIC 16f877a. i will then detect the no of waves per second. i have two questions:
1. should i just apply this 12 volts square wave directly to PIC and use A/D to determine when 12volts are present on a pin to keep count of no of pulses per second, or should i reduce the voltage to 5v through a variable resistor and then apply it to the pin and forgo the whole A/D procedure.
2. to count the no of square pulses per second, i will have to use timers, or is there a better way of doing this.
Best regards
SherpaDoug
PostPosted: Sat Oct 15, 2005 7:35 am     Reply with quote
Do not run a 12V signal straight into any PIC pin whether it is an A/D input or not! You run a good chance of damaging the PIC.
If all you want to do is measure the frequency and you don't care about amplitude you do not need to use an A/D. Read Microchip App note AN521 for info on extracting timing data from high voltage waveforms.
PostPosted: Sat Oct 15, 2005 7:37 am     Reply with quote
Reduce it to 5v. Otherwise, exit one PIC...
The 'best' method of generating the input, is probably to use an external comparator, with some hysteresis present, to give a clean square wave (otherwise you are likely to have problems if there is any noise on the signal), and then feed the signal into a timer or CTC.
How you use this, depends on the frequency involved. if the frequency is high, directly count the signal with a timer module. Otherwise, if you use the CTC in 'capture' mode, to count the clocks on the internal oscillator, between the signal edges, this gives a value directly related to the period (reciprocal of frequency). At low frequencies this will give much better accuracy.
kender
PostPosted: Sat Oct 15, 2005 7:59 pm     Reply with quote
If your 0-12V input is just a square wave with a little noise, you might get away without a comparator. I think this topology will work for:
12V input ---
             \   1k - 10k
             |------------------------------------|  digital input on a PIC
            ---  4.7V 0r 5.1V zener diode                |
            \/   GND                                    \/   GND
PostPosted: Sat Oct 15, 2005 9:05 pm     Reply with quote
                                      ____ +V for PIC
12V input ---                     |
             |                       _|_ Diode
             \   1k - 10k          |
                                                    \/   GND
Clamp the input to Vdd. using a simple 1N4148
PostPosted: Sun Oct 16, 2005 5:51 am     Reply with quote
Both the Zener method and diode to VCC are viable solutions.
For the zener method I would use a 4.7volt zener.
The diode to VCC method injects current into the VCC supply of the circuit. This would not normally be a problem however you will need to ensure that this does not compromise the regulation characteristics of the power supply circuitry in your design.
