mplab 6.20 and CCS 3.148
acid
PostPosted: Wed May 28, 2003 8:55 am     Reply with quote
<font face="Courier New" size=-1>Hello
( I ask excuse for my English )
I have installed mplab's version 6.20 but I am not still able to compile my project, mplab return this error
Deleting intermediary files... done.
Executing: "C:\WINDOWS\PICC\Ccsc.exe" "e180.c" +FM +DF +LN +T -A +M +Z +Y=9 +EA
Error: The selected compiler: "PCM" is not installed on this PC
Halting build on first failure as requested.
BUILD FAILED
I have installed plugin ccs and the compiler's path is ok
Mplab 5.20 is installed in the c:\program\mplab.." path.
it hasn't problem.
which thing I can do?
TAHNK!
</font>
___________________________
Original Post ID: 144514813
mcbrideja
Re: mplab 6.20 and CCS 3.148
PostPosted: Wed May 28, 2003 3:49 pm     Reply with quote
:=I have installed plugin ccs and the compiler's path is ok
:=Mplab 5.20 is installed in the c:\program\mplab.." path.
:=it hasn't problem.
Is Mplab 5.20 a typo? When installing mplab 6.x it instructs you to uninstall all older versions first. If you did not do that, it could be your problem.
Jim
Original Post ID: 144514822
westy
PostPosted: Wed May 28, 2003 6:24 pm     Reply with quote
:=<font face="Courier New" size=-1>Hello
:=( I ask excuse for my English )
:=I have installed mplab's version 6.20 but I am not still able to compile my project, mplab return this error
:=Deleting intermediary files... done.
:=Executing: "C:\WINDOWS\PICC\Ccsc.exe" "e180.c" +FM +DF +LN +T -A +M +Z +Y=9 +EA
:=Error: The selected compiler: "PCM" is not installed on this PC
:=Halting build on first failure as requested.
I had a similar problem, ending up reinstalling mplab and ccs to no avail. I contacted ccs - the solution is to check and ensure that you have all the .crg files in the same folder as the ccsc.exe. For some reason the ccs install did not copy them over, or something else removed them, although everything else seemed fine.
Best wishes,
Ray
Original Post ID: 144514825
acid
PostPosted: Thu May 29, 2003 1:27 am     Reply with quote
:=:=<font face="Courier New" size=-1>Hello
:=:=( I ask excuse for my English )
:=:=I have installed mplab's version 6.20 but I am not still able to compile my project, mplab return this error
:=:=Deleting intermediary files... done.
:=:=Executing: "C:\WINDOWS\PICC\Ccsc.exe" "e180.c" +FM +DF +LN +T -A +M +Z +Y=9 +EA
:=:=Error: The selected compiler: "PCM" is not installed on this PC
:=:=Halting build on first failure as requested.
:=I had a similar problem, ending up reinstalling mplab and ccs to no avail. I contacted ccs - the solution is to check and ensure that you have all the .crg files in the same folder as the ccsc.exe. For some reason the ccs install did not copy them over, or something else removed them, although everything else seemed fine.
:=Best wishes,
:=Ray
I have unistalled PCW and MPLAB 5.70 then I have reinstalled PCW and its plug-in. Now is all ok.
Thank to all
Original Post ID: 144514829
acid
PostPosted: Sat May 31, 2003 8:47 am     Reply with quote
:=:=I have installed plugin ccs and the compiler's path is ok
:=:=Mplab 5.20 is installed in the c:\program\mplab.." path.
:=:=it hasn't problem.
:=Is Mplab 5.20 a typo? When installing mplab 6.x it instructs you to uninstall all older versions first. If you did not do that, it could be your problem.
:=Jim
I have unistalled early version and is all ok now
Original Post ID: 144514910
