Hi everybody!
I have trying to work with a LCD (Fuji FCS2314AK) but I can't get the black matrix dots when power up. I think it's a problem of the contrast.
The power supply (Vcc pin 13) it's 5V, the ground pin (GND pin 12 and GND1 pin 15) are connected to ground, and what I think it's the contrast pin (Vee pin 14) has a fixed resitor that gives it 2,5V.
The LCD has been given to me and I haven't found good documentation about the display. Does anybody know where I can find documentation? Does anybody know which levels use to work? because I dont want to try it experimentally and burn the LCD.
Thank you in advance
___________________________
Original Post ID: 144514908
Tomi Guest
Re: LCD in blank
Posted: Sat May 31, 2003 7:53 am
Try to connect the contrast pin to GND (but keep in mind that there are some LCD panels typically for extended temperature range where a negative voltage is required for contrast control). That resistor is typically 10-47kOhm so this shortcut couldn't be a damage to the LCD panel.
:=Hi everybody!
:=I have trying to work with a LCD (Fuji FCS2314AK) but I can't get the black matrix dots when power up. I think it's a problem of the contrast.
:=The power supply (Vcc pin 13) it's 5V, the ground pin (GND pin 12 and GND1 pin 15) are connected to ground, and what I think it's the contrast pin (Vee pin 14) has a fixed resitor that gives it 2,5V.
:=The LCD has been given to me and I haven't found good documentation about the display. Does anybody know where I can find documentation? Does anybody know which levels use to work? because I dont want to try it experimentally and burn the LCD.
:=Thank you in advance
Original Post ID: 144514909
