muahaha98 Guest
about mark's lcd program |
Posted: Wed Oct 12, 2005 9:33 am |
I see the marks program and I add the first line -typedef char BYTE- but computer still has a lot of errors which are as
C:\savas\a.c:18:Warning [2058] call of function without prototype
C:\savas\a.c:19:Warning [2058] call of function without prototype
C:\savas\a.c:20:Error [1105] symbol 'PIN_A1' has not been defined
C:\savas\a.c:20:Warning [2058] call of function without prototype
C:\savas\a.c:21:Warning [2058] call of function without prototype
C:\savas\a.c:22:Error [1105] symbol 'PIN_A1' has not been defined
C:\savas\a.c:22:Warning [2058] call of function without prototype
typedef char BYTE;
#define use_PICDEM2_lcd TRUE
#if defined use_PICDEM2_lcd
#define lcd_en PIN_A1
#define lcd_rw PIN_A2
#define lcd_rs PIN_A3
#define lcd_type 2 // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40 // LCD RAM address for the second line
#define d_cycle 1
#endif
void lcd_send_nibble( BYTE n ) {
n=n&0x0f; //Strip off the top 4 bits.. This only sends bit 3:0
output_d(n);
delay_cycles(d_cycle);
output_high(lcd_en);
delay_us(20);
output_low(lcd_en);
BYTE lcd_read_byte() {
BYTE low,high;
output_high(lcd_rw);
high = input_d(); //using d0:d3 for 4 bit data bus
output_low(lcd_en);
delay_us(1);
low = input_d(); //using d0:d3 for 4 bit data bus
output_low(lcd_en);
return((high<<4) | low);
void lcd_send_byte( BYTE A0, BYTE n ) { //A0: 0=instruction, 1=Data
output_low(lcd_rs);
while ( bit_test(lcd_read_byte(),7) ) ; // wait until busy flag is low
if (A0==0){ output_low(lcd_rs);} //0=Instruction and 1=Data
if (A0==1){output_high(lcd_rs);} //0=Instruction and 1=Data
output_low(lcd_rw);
output_low(lcd_en);
lcd_send_nibble(n >> 4);
lcd_send_nibble(n & 0xf);
void lcd_init() {
BYTE const LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
// These bytes need to be sent to the LCD for initialization.
BYTE i;
//fprintf(debug,"Init!!\n\r");
output_low(lcd_rs);
output_low(lcd_rw);
output_low(lcd_en);
delay_ms(15);
for(i=1;i<=3;++i) {
lcd_send_nibble(3);
delay_ms(5);
lcd_send_nibble(2);
for(i=0;i<=3;++i){
lcd_send_byte(0,LCD_INIT_STRING[i]);
void lcd_gotoxy( BYTE x, BYTE y) {
BYTE Data;
if(y!=1)
Data=lcd_line_two;
Data=0;
Data+=x-1;
lcd_send_byte(0,0x80|Data);
void lcd_putc( char c) {
switch (c) {
case '\f' :
lcd_send_byte(0,1);
delay_ms(2);
case '\n' :
lcd_gotoxy(1,2);
case '\b' :
lcd_send_byte(0,0x10);
default :
lcd_send_byte(1,c);
char lcd_getc( BYTE x, BYTE y) {
char value;
lcd_gotoxy(x,y);
while ( bit_test(lcd_read_byte(),7) ); // wait until busy flag is low
value = lcd_read_byte();
output_low(lcd_rs);
return(value);
treitmey
Posted: Wed Oct 12, 2005 9:54 am |
This compiles.
you need to have your functions physically before main().
OR use prototypes
Code: | #INCLUDE <18F452.H>
#CASE
#USE DELAY(CLOCK=16000000) //********************************* ! ! ! ! ! !
#FUSES HS,NOWDT,NOPROTECT,NOLVP
#DEFINE VER_MAJOR 0
#DEFINE VER_MINOR 01
#USE RS232(BAUD=19200,XMIT=PIN_E0,INVERT,STREAM=DEBUG)
#ZERO_RAM
#define d_cycle 1
#endif
output_d(n);
delay_us(20);
output_low(lcd_en);
BYTE low,high;
output_low(lcd_en);
delay_us(1);
output_low(lcd_en);
output_low(lcd_rs);
output_low(lcd_rw);
output_low(lcd_en);
void lcd_init() {
BYTE i;
output_low(lcd_rs);
output_low(lcd_rw);
output_low(lcd_en);
delay_ms(15);
for(i=1;i<=3;++i) {
lcd_send_nibble(3);
delay_ms(5);
lcd_send_nibble(2);
for(i=0;i<=3;++i){
BYTE Data;
if(y!=1)
Data=lcd_line_two;
Data=0;
Data+=x-1;
switch (c) {
case '\f' :
lcd_send_byte(0,1);
delay_ms(2);
case '\n' :
lcd_gotoxy(1,2);
case '\b' :
default :
lcd_send_byte(1,c);
char value;
lcd_gotoxy(x,y);
output_low(lcd_rs);
return(value);
setup_adc_ports(NO_ANALOGS);
set_tris_a(0);set_tris_b(0);set_tris_c(0);set_tris_d(0);set_tris_e(0);
fprintf(DEBUG,"STARTING CRI Test.\n\r");
fprintf(DEBUG,"FIRMWARE VERSION %u.%02u\n\r",VER_MAJOR,VER_MINOR);
printf(lcd_putc,"FIRMWARE VERSION %u.%02u\n\r",VER_MAJOR,VER_MINOR);
while (TRUE)
muahaha98 Guest
to treitmey |
Posted: Wed Oct 12, 2005 10:11 am |
I added these codes which you said
but computer still systax error
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F452 "a.c" -fo="a.o" /i"C:\mcc18\h" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
C:\savas\a.c:1:Error: syntax error
Halting build on first failure as requested.
[/code] |
Posted: Wed Oct 12, 2005 10:17 am |
You need to buy the CCS compiler to use code that has CCS functions.
You can't use code that calls built-in CCS functions with the C18 compiler. |
muahaha98 Guest
which compiler? |
Posted: Wed Oct 12, 2005 10:26 am |
which compiler shoolud is used?
please tell programm ne? |
Mark
Posted: Wed Oct 12, 2005 11:01 am |
C18 has their own LCD functions. |
