Help with QEI
aaaaamartin
Help with QEI
PostPosted: Tue Oct 11, 2005 11:11 am     Reply with quote
I want to use the built in QEI on a 18F4431 with a quad encoder.
No its not the one you mount to the motorshaft, its one for manual data entry. However this is much slower, i think why not use the QEI for that as wel.
The problem is, I can not figur out why the interrupts happen more than once. And this is also different right after direction changes and whether I rotate cw or ccw.
Is this normal behaviour ?
Heres is some code if one has an encoder to try out.
#ZERO_RAM
#include <18F4431.h>
#fuses NOWDT, H4, NOPUT, NOPROTECT, NOBROWNOUT, NOLVP, NOCPD, NOWRT, NODEBUG, SSP_RC
#use delay(clock=40000000)
#use rs232 (baud=38400, xmit=PIN_C6, rcv=PIN_C7, disable_ints)
#BYTE QEICON=0xFB6  // quadrature configure
#bit  QEICONDIR=0xFB6.5
#BYTE DFLTCON=0xF60  // quadrature noise filter configure
#BYTE CAP2BUFL=0xF66 // position counter
#BYTE CAP2BUFH=0xF67
#BYTE CAP3BUFL=0xF64  //max count
#BYTE CAP3BUFH=0xF65
int drcnt;
int qeicnt;
#int_IC3DR
void ic3dr_interrupt (void) {
   output_toggle (PIN_D0);
   drcnt ++;
#int_IC2QEI
void ic2qei_interrupt (void) {
   output_toggle (PIN_D1);
   qeicnt++;
void main (void) {
    enable_interrupts (INT_IC2QEI); // interrupt on maxcount or underflow
   enable_interrupts (INT_IC3DR);
    enable_interrupts (GLOBAL);
   QEICON=0b00011000; // quad in x4 mode, resettable by maxcount
   DFLTCON=49; // noise filter on QEA, QEB,, 1:2 clock
   CAP3BUFL=0x0F;  // set max count
   CAP3BUFH=0x00;
   CAP2BUFL=0x00;  // reset   count
   CAP2BUFH=0x00;
    while (1) {
       printf("\rCAP2:%X-%X ; CAP3:%X-%X ; QEICON:%X ;qeicnt %03u ; drcnt: %03u", CAP2BUFH, CAP2BUFL, CAP3BUFH, CAP3BUFL, QEICON, qeicnt, drcnt);
                delay_ms (50);
Thanks you, Martin
kender
$0.02 hardware hypothesis
PostPosted: Tue Oct 11, 2005 5:20 pm     Reply with quote
Are you using a mechanical encoder or an optical one?
Mechanical encoders have the bouncing problem, because they have mechanical switches. If you want to connect a mechanical encoder to the interupt, you need to debounce all of its outputs. There is a sample circuit at the bottom of page 1 of this datasheet: http://www.bourns.com/pdf/ecw1j.pdf
Optical encoders don't have this problem.
aaaaamartin
PostPosted: Wed Oct 12, 2005 3:51 am     Reply with quote
It's a mechanical encoder by ALPS.
I dont't think it's a debounce problem.
It's working in both directions, and in all cases counts one time,
except I change direction from cw to ccw, then it counts -3 right after the change. Then it coutns -1 again, as it should.
Martin
sseidman
PostPosted: Wed Oct 12, 2005 8:29 am     Reply with quote
Martin
I'd still start by debouncing. The noise filters on the QEI might take care of all the problems, except during the direction change you describe.
Scott
aaaaamartin
PostPosted: Wed Oct 12, 2005 8:54 am     Reply with quote
I'll do a software workarround.
If anyone else thinks this abnormal .....
Martin
