Working on 16F877, not on 18F4550. Why ?
Bart
PostPosted: Tue Oct 11, 2005 2:55 pm     Reply with quote
Can't find why the below code won't work on me 18F. It worked fine on a 16F877.
I made some changes in my hardware (and also my code) between 16F and 18F :
* use of INT2 i.p.o. INT
* RS232 on other pins (but it is working fine, I get the version info in the Hyperterminal)
* other LCD driver (but it is working fine, I get the version info on the LCD)
It seems that I don't get the char's with the fgetc(GPS). But the char's seems to be there (on the pin) becase I receive interrupts (checked by printing - - - - - in the Hyperterminal via the fprintf(MODEM," - %S",c)
Someone an idee ?
Thanks.
// VERSION : 0.1.03
//  * blinking blue led
//  * RS232 (E0 E1) : GPS stream to PC
//  * RS232 (B2 B3) : GPS stream to PIC
//  * LCD 4x20 : version displaying on LCD
#include <18F4550.h>
#fuses HS,NOWDT,NOPUT,NOLVP,NOBROWNOUT,NOCPD,NOWRT
#use rs232(baud=9600, xmit=PIN_E1, rcv=PIN_E0, stream=MODEM)
#use rs232(baud=4800, xmit=PIN_B1, rcv=PIN_B0, stream=GPS)
#include <LCD4x20D.C>
#define GPS_BUFFER_SIZE 70
static char    GPS_buffer[GPS_BUFFER_SIZE];
static char    GPS_code[]  = "$GPRMC";
static char*   GPS_p       = GPS_buffer;
static int     GPS_state   = 0;
static short   GPS_done    = TRUE;
static short   GPS_found   = FALSE;
#int_ext2
void GPS_isr()
   char c;
   c = fgetc(GPS);
   fprintf(MODEM," - %S",c);
   if( GPS_found == FALSE )
      GPS_found = TRUE;
   if( GPS_state < 6 )
      if( c == GPS_code[GPS_state] )
         if( GPS_state == 0 )
            GPS_p = GPS_buffer;
         *GPS_p = c;
         GPS_p++;
         GPS_state++;
         GPS_state = 0;
      if( c == 0x0d )   // carriage return
         *GPS_p = 0;
         GPS_done = TRUE;
         disable_interrupts(INT_EXT2);
         *GPS_p = c;
         GPS_p++;
         GPS_state++;
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_vref(VREF_LOW|-2);
   setup_low_volt_detect(FALSE);
   setup_oscillator(False);
// Version output to RS232 PC Hyperterminal (stream MODEM)
fprintf(MODEM,"\033[2J");     // clear screen
fprintf(MODEM," PIC Online\n\r");
fprintf(MODEM," Version : 0.1.03\n\r");
fprintf(MODEM," Copyright 2005 Bart De Pauw\n\r");
fprintf(MODEM," For PIC 18F4550\n\r");
fprintf(MODEM," GPS stream to PC\n\r");
//   Version output to LCD
lcd_putc("\f**** PIC Online ****\n");
lcd_putc("Copyright 2005 \n");
lcd_putc("V0.1.03 Bart De Pauw\n");
lcd_putc("* GPS stream to PC *\n");
//        12345678901234567890    (Help for alligning messages on LCD)
// GPS tx is connected to pin RB2 (pin 35) so INT2
   ext_int_edge(2,H_TO_L);
   enable_interrupts(INT_EXT2);
   while (TRUE)
   if( GPS_found && GPS_done )
      fputs(GPS_buffer,MODEM);
      GPS_state = 0;
      GPS_done = FALSE;
      output_HIGH(PIN_A0);
      output_LOW(PIN_A0);
I like Skype (www.skype.com), my username is BplotM
PostPosted: Tue Oct 11, 2005 7:24 pm     Reply with quote
VERSION : 0.1.03
The pins in the comments don't match the #use rs232() statement.
Is the GPS connected to pins B2 and B3, or pins B1 and B0 ?
If that's not the problem, then post your compiler version.
