PIC16F914 input on unused VLCD pin C2
Birdie
PostPosted: Thu Oct 06, 2005 7:54 am     Reply with quote
Hello All,
I am using PCWH 3.235 and a PIC16F914 with a static drive LCD.
I have connected a N/O pushbutton and pull-up resistor to the RC2/VLCD3 pin; when the pushbutton closes RC2 sees ground.
The problem: when I push the button the LCD segments go completely blank.
When I release the button the segments are normal.
The compiler creates this:
...................    setup_lcd(LCD_STATIC);
0BA3:  MOVLW  80
0BA4:  BCF    03.5
0BA5:  BSF    03.6
0BA6:  MOVWF  07
0BA7:  CLRF   08
and this for the pushbutton
....................    if(input(PIN_C2) == 0)
02DE:  BSF    03.5
02DF:  BSF    07.2
02E0:  MOVLW  00
02E1:  BCF    03.5
02E2:  BTFSC  07.2
02E3:  MOVLW  01
02E4:  XORLW  00
02E5:  BTFSS  03.2
02E6:  GOTO   31C
Any suggestions much apprecated.
Thank you,
Birdie
PostPosted: Thu Oct 06, 2005 12:51 pm     Reply with quote
The setup_lcd(STATIC) code appears to be correct. It is disabling
the LCD bias voltage, so pin C2 should be a normal i/o pin.
What code is being executed after the if statement ?
You don't have to post the ASM code. Just post the C code.
Birdie
PostPosted: Fri Oct 07, 2005 7:50 am     Reply with quote
Thanks for the response.
It makes no difference what the code is, or even if there is code; if the pin gets grounded, the LCD goes blank. I am going to try to switch the wiring so the pushbutton is on a different (not VLCD) I/O pin.
I'll post the results.
Thanks again.
Birdie
PostPosted: Sat Oct 08, 2005 2:25 pm     Reply with quote
Well I managed to swap pins and get the LCD to work when the button is pressed.
It seems that the VLCD3/RC2 pin will cause the LCD to blank if brought to logic 0 (either by hardware {push button} or by code!
I wonder if there is some setup I'm missing.
Neither VLCD2 nor VLCD1 cause the LCD to blank, only VLCD3.
adrian
PostPosted: Mon Oct 10, 2005 5:49 am     Reply with quote
Have a look at this post from the Microchip forum..
http://forum.microchip.com/tm.asp?m=114122&mpage=1&key=lcd&anchor#114144
