not enough ram problem
vin
PostPosted: Sun Oct 09, 2005 2:55 am     Reply with quote
Dear Sir,
PIC 16f877A is using for my present work. while combiling using CCSC "not enough ram" error is popup. from the data sheet the information is that general pupose ram locations are greater than 300 bytes. but in my project the worst cause usage is below 160 bytes. Anyone know the reason?.
vineesh.A
arunb
RE:
PostPosted: Sun Oct 09, 2005 5:43 am     Reply with quote
Check the .tre file and see which of the functions/procedures are using a large amount of RAM, then breakup these procedures into smaller ones.
That way you can save a large amount of RAM
thanks
arunb
PostPosted: Sun Oct 09, 2005 10:33 pm     Reply with quote
hello,
Thanks to your repalys . i got the answer from Ttelmah. since #device *=16 is not used compiler only select first bank. so the problem arise. thanks to all.
vin
